Red Triangle, MFD Error Message
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bluesparky, Nov 18, 2009.
  1. bluesparky
    bluesparky Prius v -Five ATP Blizzard Pearl
    16
    Troutville, VA
    :confused:For the past few days, when I pressed the brake pedal and turned on the power to get ready to drive, the red triangle/exclamation point would come up on the dash with all the yellow icons beside it, and the MFD would not always come on. Sometimes, the vehicle would never show "Ready", and the power button was orange in color. You could hear some relays clicking and the whirring of the pump under the hood, but no "Ready" light. I would have to press the power button again before it would go to green and the "Ready" light would come on on the dash so I could drive the car.
    Finally, I saw an error message for about 1 second on the display last night when I was trying to get it to do it again, and it said something about "There is a problem with the "P"" and I couldn't read fast enough to get it all. This came up after about 10-12 times of turning the power on and off. I gave up and went to bed.
    This morning, I got smart and got my video camera and held it to watch the dash for me while I pressed the power button. Guess what? No red triangle or error mesage! Par for the course! At lunch, I went out from work and tried it again, and on the 2nd attemp, I videoed the triangle and the message! It said "There is a problem with the transmission "P" park lock mechanism. Please park your vehicle on a level surface and engage the parking brake..." or something to that effect.
    I have called the dealer to take it in on Monday. I only have 29,655 miles on the '07 model, so it is under warranty, but what is the problem, and what should I expect?
  2. Patrick Wong
    18,200
    6,493
    Most likely, the problem is that your 12V auxiliary battery needs to be replaced.
  3. djasonw
    djasonw Active Member
    960
    121
    Coconut Creek, FL
    It seems a lot of these quirks are remedied by changing the 12volt battery. What I think should be done in future models is some type of gauge that monitors the voltage and health of this battery. Does anyone know if the scangauge is capable of that? TIA
  4. richard schumacher
    7,664
    1,043
    United States
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I'm sure it's the 12v. battery. Others have reported the same error message and it wound up being the 12v. battery on it's way out.
  6. moneytrain8
    moneytrain8 New Member
    74
    Joppa, MD
    I had this same issue multiple times over the last year. I would be driving along, nothing unusual, and I would get that message ("There is a problem with the transmission "P" park lock mechanism. Please park your vehicle on a level surface and engage the parking brake").
    The first time I freaked out and pulled over and they towed me into the dealership and said they found a "bunch" of error codes. They couldn't figure out what was wrong.
    It happened a few months later while I was two hours from home, driving to VA Beach. I pulled over and started calling to figure out what to do. After about 10 minutes of waiting, I tried to restart the car. It restarted fine without issue.
    Then, about 4 months ago, it happened a third time. I drove it all the way to the dealership. They took it in and told me the ECU (computer?) was bad and needed to be replaced. $550 later (I fought and got them to take off the labor charges) and I have not had the problem since.
    I'm in a 2005 Prius at 97,000 miles. The first instance was at about 62,000 miles. If it was the battery, would it have been covered?
    You can bet I'm going to raise holy heck if the error every happens again, especially after reading this thread.
  7. richard schumacher
    7,664
    1,043
    United States
    It would have been covered. In fact the ultimate cause (whatever it is) is still covered since you raised the issue during the warranty period. If a bad battery is the cause then they owe you a new one, although proving that it's been the battery all along may be difficult. (And in fact that seems kinda unlikely: a battery that was bad 35,000 miles ago probably would have died long since. But perform the self test, or even just a voltmeter check, and see what you get.)
  8. moneytrain8
    74
    Joppa, MD
    They told me it was only a 60k warranty, so it wouldn't have been covered even if they had been thorough enough to find it the first time.
    She showed me the error code for the problem, and it matched one of the codes they found the first time (amongst 10 others).
    AH, I see the self test link... I'll have to try when I get my car back tonight. Thanks for the info!
  9. richard schumacher
    7,664
    1,043
    United States
    D'ohh!! Sorry, brain fart on my part: I was thinking 100K miles. No, the 12V battery was out of warranty at 62K. For a pointer to the 12V battery self test see a couple of posts back.
  10. bluesparky
    16
    Troutville, VA
    Well, I owe an apology. I found I never came back and reported the issue, but you were right. It was the 12V battery in the back. That fixed it!
  11. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Better late than never
  12. bluesparky
    16
    Troutville, VA
    I'd heard that before somewhere! Must be true....
