Red Triangle no code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hakam, Apr 10, 2023.
  1. Hakam
    Hakam Junior Member
    Jordan, Amman
    Hai folks. Recently, the red triangle of death showed up while driving, it did nothing and sometimes it disappear and other times reappear. Many said it is the inverter pump but i noticed it works just fine and oil is not low. I had obd2 and managed to get these codes but I don't think any of them has something to do with that. Some mechanic told me that there might me some water that went inside of the vehicle compartment that caused this issue, and that is why the triangle is disappearing and reappearing. Anyone got any ideas?. And I don't have a catalytic invert and my abs is almost dead.
    Here are the codes
    Car Scanner ELM OBD2
    Version: 1.98.0/400980/GP
    DTC report
    Connection profile: Toyota Prius Gen. 2 (2004-2009)Date: 4/10/2023 3:43:53 PM
    VIN: JTD
    OBD-IIOBD-II
    DTCs: 5
    P0037 [0x0037]
    Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit low
    Oxygen Sensor Heater Circuit Low Input (Bank 1, Sensor 2)
    Status: Confirmed
    P1121 [0x1121]
    Throttle Position (TP) Sensor Circuit Intermittent High Voltage
    Accelerator Pedal Position Sensor Range / Performance Problem
    Status: Confirmed
    P1123 [0x1123]
    Throttle Position Sensor In Range But Higher Than Expected
    Status: Confirmed
    U0100 [0xC100]
    Data bus, engine control module (ECM) A - no communication
    Status: Confirmed
    U0111 [0xC111]
    Data bus, battery energy control module A - no communication
    Status: Confirmed
    Engine control unit #1
    No DTC found.
    Hybrid engine systemHybrid engine system
    DTCs: 2
    U0100 [0xC100]
    Status: Confirmed
    U0111 [0xC111]
    Status: Confirmed
    HV battery
    No DTC found.
    49,377
    it could be corrosion or a bad ecu connector. how is the 12 volt health?
    tech stream might present some helpful sub codes
  3. ChapmanF
    15,436
    The U codes for the hybrid system could certainly light the triangle.
