Red Triangle of Death with temperature warning?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mmmitch, Aug 14, 2019.
  1. mmmitch
    mmmitch New Member
    fl
    i have a 2008 prius with something like 180k miles on it. the other day while driving the red triangle of death started flashing intermittently, accompanying it in the touch screen display was the word "problem" followed by what looked like a red temperature sign. it didn't impair my ability to drive at all, so i hurried home & haven't driven it since.
    i was driving, so i couldn't take a picture, but i found some one else on the net who had the same issue, their display is exactly like mine.
    it's probably worth mentioning that prior to these shenanigans, i had the ac amplifier replaced and also a wheel bearing. i don't know if that could be related but quite frankly, nothing surprises me anymore.
    any ideas anyone?
  2. Patrick Wong
    18,200
    6,474
    Have you checked the coolant level in 3 places:
    1. Engine radiator (remove the cap so you can see inside)
    2. Engine coolant overflow reservoir
    3. Inverter coolant reservoir
    Also, what is the condition of the engine coolant pump and the serpentine belt that spins the pump pulley?
  3. JC91006
    16,482
    8,399
    You might have a failed inverter pump
    I would check your oil level while you're checking your coolant levels
    mmmitch and Raytheeagle like this.
  4. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    270
    551
    Dallas -Fort Worth
    The high temp warning on the MFD comes on when the ICE reaches 250F. Fill and bleed the radiator before driving the car anymore. Neither of the repairs you mentioned should have required messing with the engine cooling system but if they did happen to drain it chances are they didn’t get all of the air out.
  5. mmmitch
    mmmitch New Member
    fl
    based on prior suggestions, i checked the coolant levels and made sure that was fine. i cranked it once when i saw the red triangle again and had someone run a diagnostic on it - it churned out P0A7A with the message "generator inverter performance".
    the battery in the trunk - the auxiliary battery i suppose? gave a low voltage reading, about 10~11v. i took it out, dragged it to autozone to be charged and brought it back. i tried again - vehicle cranked once and now it's quiet. there are no companion codes to that, i'm stumped. i feel like this car just won't quit.
    please see my message above, do you think the failed inverter pump fits the bill?
  6. mmmitch
    mmmitch New Member
    fl
    i managed to crawl it into the garage, these are the error messages being displayed. i hope its visible.
  7. bisco
    49,472
    you need a prius aware scanner
    mmmitch and Skibob like this.
  8. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    You got the high temp warning and kept driving? How far? It’s quite possible you cracked the head by overheating the engine. Check your oil to see if it looks funny. Check your coolant for signs of oil also. If your car had a temperature gage and it was in the red would you continue to drive the car? That light is your temperature gage in the red.
    #8 Skibob, Aug 28, 2019
  9. mmmitch
    mmmitch New Member
    fl
    the light was intermittent - it would be fine for stretches of time, then flash for a few seconds and go away. i was on a stretch of rural highway, so i just went home & parked it. i'll check my oil & coolant as suggested, thanks.
  10. dolj
    dolj Senior Member
    7,652
    3,863
    Wellington, New Zealand
    @mmmitch, did you do this yet? Do not drive your car until you do.
