Red triangle, temperature warning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ty606, Jan 14, 2021.
  1. Ty606
    Ty606 Junior Member
    Madison, wi
    Hey there! Bought my first Prius a week ago and having an issue already. 2005 with 160k.
    When I’m on the highway the red triangle exclamation light comes on the dash with a red thermometer on the nav screen.
    No check engine light.
    Sometimes the heat in the cabin works well and then it seems to go cold.
    Coolant reservoirs are full but there is a small puddle of coolant beneath the engine, passenger side towards the front. I cannot find the source of it.
    Anyone know what pump or valve would only have issues at higher speeds? Where is the best place to start?
  2. PriusCamper
    PriusCamper Senior Member
    11,059
    4,502
    Pacific Northwest, USA
    Reading the error codes and subcodes will give us more specifics. Do you have a friend who has Toyota Techstream software on their laptop? Or maybe someone with and OBD2 reader so you can use Dr. Prius app on your phone? Here's buyers guide for OBD2 reader: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Or if you just want to live your life and have it dealt with by someone else and can afford a top notch hybrid shop to fix it, you're living in the right town: EV Powers | Hybrid Battery Service & Repair. Prius Insight Civic. 56 Corry St, Madison, WI
  3. ChapmanF
    15,457
    Higher speeds usually require more engine power, producing more heat. It's possible there isn't anything with "issues at higher speeds", but just that somehow the cooling system's overall heat-removing capacity is reduced, and you hit that limit at higher power levels.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    Fluid being visible at the passenger side front is often indicative of the water pump seals failing. The water pump is located on the passenger side front bottom area of the engine. Take a flashlight and look at it. You specifically want to look at the back of the pulley, because coolant will collect there when the seal is failing. It should be a pink color. Slow weepage usually results in a crusty pink layer in the backside of the pulley. A more significant leak leaves it wet. If it's dry and crusty, it's not an immediate crisis. If it's wet, you better get on it.
    Most often, the people compartment heat being intermittent is a pretty reliable sign that engine coolant is getting low, regardless of what's in the overflow tank.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Hope your not using the over flow tank as a gauge of coolant in the rad as that does not work well.
    Take the plastic cover that's on the top of the rad off its six screws under there is the rad cap. I bet the rad is pretty empty hence the thermometer on the dash.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    This could be a sign of:
    Water pump failure.
    Plugged radiator core.....or plugged external fins on radiator.
    And I hate to mention: Leaking head gasket. Check the oil for signs of water.
