red triangle testing
Discussion in 'Gen 2 Prius Technical Discussion' started by TheGMann, Oct 24, 2021.
  1. TheGMann
    TheGMann Junior Member
    wisconsin
    Narrowing down causes
    Hey Guys: I saw a video where they narrowing causes of the red triangle by first powering the system up, triangle yes-no. If no then energizing the HV battery - red triangle yes-no, then testing the inverter yes-no.
    I thought this vid was helpful,
    My question: is the red triangle real time error (only on if the system failure occurring) or is it like a code error that needs to be reset?
  2. ChapmanF
    17,326
    The procedure you saw was for narrowing down the cause of a P0AA6 code, the code that means there is an electrical isolation fault somewhere in the car. If P0AA6 is the code you have, that procedure will help you figure out if the fault is in the battery, frame wire, inverter, transaxle, air conditioner, etc.
    If P0AA6 is not the code you have, that procedure won't tell you anything useful.
    P0AA6 is one of around a couple hundred possible trouble codes that can light that triangle.
    So if you see the triangle come on and you just sort of guess that P0AA6 is the reason, without reading the codes, and then start working through tests that are for P0AA6, you're kind of assuming a lot.
    Reading the codes first can save you some trips down rabbit holes.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,962
    1,911
    NJ-USA
    Besides having one or more codes in one of many different electronic systems, there are also a few possible things that could trigger the "master warning light" (red triangle) without necessarily setting a code (I believe brief low engine oil pressure can do this).
    So, if you have the warning light come on, then it's best to check all the underhood fluids for level and condition, then scan ALL the systems on the car with a Prius compatible scantool (such as Techstream). Many aftermarket scantool report "no codes present" when there are codes - but the scantool just can't access them.
    Whatever caused one of the systems to trigger the light is unlikely to "fix itself" because you just cleared the code.
  4. TheGMann
    wisconsin
    I do have two codes, P0AC0, P3191
  5. TheGMann
    wisconsin
    replaced the hybrid battery with another, cleared codes and all seems good for now. I do get a good spark when I hook up the 12V Battery. That was the premise of the original question to try and find the drain
  6. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    I guess changing the entire HV battery is one way to fix a problem with the current sensor.
