red triangle, TPMS, VCC and check engine lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by G.Smith, Dec 2, 2024.
  1. G.Smith
    G.Smith New Member
    Quebec
    Three Touring
    I was driving today when suddenly the car slowed and the red triangle, TPMS. VCC and check engine lights came on. I was able to get home but had trouble going up hills. The engine starts right up but now the hybrid cooling fan is on high. Any ideas what the issue could be?
  2. JC91006
    16,769
    8,567
    Your issue is 99% related to a failed hybrid battery
    Brian1954 likes this.
  3. G.Smith
    G.Smith New Member
    Quebec
    Three Touring
    Could the 12v battery be causing these issues? When it happened the hybrid battery charge went to full green on the screen.
  4. Brian1954
    Brian1954 Senior Member
    2,230
    877
    South Central PA, USA
    Very doubtful. When the car is running (in ready), the 12v system in the car is powered by the DC/DC converter, which is located inside the inverter assembly. The 12 v battery is also being charged. So the car is not drawing power front the 12v battery.
    You need to get the trouble codes by using a scan tool and then post them for additional help.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,975
    NJ-USA
    One of the common symptoms of a failing hybrid battery is that the gauge on the MFD quickly goes between very high (6-8 bars) and very low (1-2 bars).
  6. pasadena_commut
    pasadena_commut Senior Member
    2,657
    789
    Southern California
    Most of that symptom list could have been a failed inverter pump, but the HV fan on max suggests instead that the HV battery overheated, which won't happen if that pump goes. That HV battery is probably going, but perhaps check the cooling fan and make sure it isn't packed up (with dust and/or human/pet hair), which could also cause it to overheat. And like the others said, pull the codes.
