Red Triangle, vs, Chk Eng After Oil Change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sutherlandws, Mar 5, 2012.
  1. sutherlandws
    sutherlandws Junior Member
    Spring, TX
    Hello. I am new to the forum. I checked similar threads but have had no luck finding a good solution.
    I have a 2007 Prius (not Touring) with 88.5K miles on it. All oil changes have been Synthetic Blend. Changed oil ~ every 5000-7500 miles. Car has been running fine. Just took it into a local auto place for an oil change 2 days ago. I picked up the car and started driving home. ~ 0.5 mi from the shop, 4 dash lights came on simultaneously: Large Red Triangle with !, the letters VS (I think that was it), the Check Engine light and one other I cannot recall.
    I turned around and drove back to the shop all on battery (intentionally). I was surprised I could, since I started with 6 bars. I got to a traffic light just before the shop and was at 2 purple bars. For the past 4 years, any time I had 2 bars and started from a stop, the engine would kick in and start charging the battery. This time it did not.
    Got it to the shop. Shop employee came out and turned on the car, saw the warning lights. He backed up the car, then stopped. I 'think' he pushed the gas pedal and the engine did not turn on. I 'think' he put it into Battery mode to drive it into the garage portion. I say 'I think' because I was outside the car. I know the engine did not come on.
    They tried to get some sort of error code, but could not because, they said, the battery was too low. However, the engine never kicked in to start the battery.
    I know there was gas in it, since I had just filled it a week before. I had ~ 320 miles on the car and had just reached 1/2 tank level (I admit to being a bit anal about that), with 63.7 mpg for that tank so far (I mention this for a reason, see below). No tech available on Sunday, and they are still testing on Monday at noon. I called today and they still wanted to say it was something to do with the battery.
    Reason for stating the mpg: For every oil change I have had on the car, I noted that the current tank mpg was always 2-3 mpg less when I picked it up then when I dropped it off. I assumed that this was because the need to run the engine in idle as part of the oil change. THIS time, the MPG in was 63.7, and out was 63.7. My wife says that she does not think that they need to run the engine for an oil change, but I am not so sure (given my past experiences).
    So, any ideas what would cause all these lights to suddenly come on just after an oil change? I have my suspicions. My guess is that they forgot to put oil in, so I drove 0.5 mi with no oil and the engine safety system shut down the gas engine to save it. Does a Prius have such a feature?
    If they accidentally put in regular oil (not synth blend) in the engine when it has always had the synth blend, would that cause this issue?
    Any help would be appreciated. Please cc any replies via my email, since I'll get that sooner than this forum (I'm at work).
    Sorry for such a long initial post, but I wanted to include as much detail as possible to help with a diagnosis.
    Scott
  2. Patrick Wong
    18,200
    6,472
    Hi Scott,
    The Prius engine does not have a "safety system" as you hypothesized above. The use of regular oil vs. synthetic would not cause a problem.
    Is the 12V battery original equipment or has it been replaced? It is certainly possible that a near-dead 12V battery may cause some of the problems you noted. Pls do not confuse this battery with the high voltage traction battery whose state of charge is monitored via the gauge on the MFD.
    uart likes this.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    This sounds like a common problem, too much oil added in, combined with another common problem, a weak 12V battery that runs down quickly with key on/engine off ("Ig-on") and erases the codes in the process.
    If you had no oil, you would have the Red Triangle and the oil light showing. I don't know offhand if it would light the ABS/VSC lights.
    Any chance you or someone at the quick lube check the dipstick?
    uart likes this.
  4. smokiejoe
    smokiejoe Member
    178
    30
    PA
    The Garage may have run down the 12v Battery.
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Probably too much oil was added. It gets frothed up and sucked through the PCV into the intake, fouling the system. We've heard a few similar stories to this here.
    There may be an issue with a flat battery now, but the original problem was likely an overfill.
  6. Veronica_87
    Veronica_87 New Member
    Stockton
    I have a 2005 Prius every time i go to the dealer for an oil change all lights turned on and I can’t drive my car, I looked at some forums and my husband checked the hybrid battery and one panel is low, he replaced it and everything went back to normal, after 6 months my car wont moved in the middle of the road, towed and checked again but this time no triangle light or vsc turned out conventional battery died, bought a new battery at the dealership and my husband replaced it, then it was fine again, after a month maintenance lights turned on, due to oil change since its been 7 months (city driving and sometimes hi-way) took the car to the dealership for an oil change, after 3 hour at the dealer i drove the car from stockton to Elk Grove parked and went to market, start the car and about 1 mile all lights turned on again triangle vsc and cant move the car to drive, my husband pushed the car and towed back to dealership, cost me $95 additional cause its far, and Toyota stockton will check my prius what seems to be the problem, and looking at all the responses here it seems like toyota missed checking my car.
  7. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Welcome!
    How many miles on the car?
    It looks like you had several issues here. I notice you mentioned that your husband replaced a bad module in the hybrid battery. Did he rebalance the pack and verify all modules were very close to the same voltage?
    Replacing a bad module in an old hybrid battery pack with another old module is not recommended here unless there is no other option, due to cost and you have another reliable vehicle. Another module will cause issues, disabling the car and requiring disassembly again.
    Other than taking a chance on modules from a low mileage wrecked Prius, the best DIY solution I have seem is the pack of new cells from user @2k1Toaster here for $1600 delivered.
    Many people here use the Prolong reconditioning system from Hybrid Automotive (@jeff652 here) to extent the life of older hybrid batteries before they fail. Users like @jerrymildred , @Raytheeagle and others can provide their experiences.
    We have many battery experts here like @TMR-JWAP , @ericbecky , @Texas Hybrid Batteries who will be along shortly.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • How did your husband check the hybrid battery?
    • With Techstream or another software program? If you have this, you can read codes so why use the Stockton dealer?
    • Sounds like he is confident with module swapping, why not change the oil as it is a lot easier:whistle:?
    • How many miles on your Prius?
    • Do you check the oil after the oil change to ensure it isn’t overfilled?
    • When the dash lights come on, do you notice a difference in performance?
    • Can you supply the codes when read by Stockton Toyota?
    Keep us posted (y).
    #8 Raytheeagle, Dec 30, 2017
    Mendel Leisk and Prodigyplace like this.
  9. Mendel Leisk
    38,652
    Sounds like that husband is a champion, btw. (y)
    Prodigyplace and Raytheeagle like this.
  10. Prodigyplace
    11,696
    11,318
    Central Virginia
    Yeah, she got a keeper. :D
  11. Veronica_87
    Stockton
    Bought it 2nd hand, 222k miles, he balanced all modules, this is the second time it happened to my prius every time i asked for an oil change.
    So since they’re the last one who touched my car i want them to give me free diagnostic to it. Since we change one module i was able to use it for 9 months. Thank you so much for all your helpful responses
    QUOTE="Prodigyplace, post: 2654473, member: 149239"]Welcome!
    We have many battery experts here like @TMR-JWAP , @ericbecky , @Texas Hybrid Batteries who will be along shortly.[/QUOTE]
    Raytheeagle likes this.
  12. Veronica_87
    Stockton
    Yeah he’s a keeper
  13. Veronica_87
    Stockton
    Thank you!
  14. bisco
    49,392
    at 222k, it could be anything. maybe your husband should teach you how to change the oil, it isn't difficult.
    Prodigyplace likes this.
  15. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    [/QUOTE]
    How did he balance the modules? Individually? Grid charger?
  16. Veronica_87
    Stockton
    Hello guys sorry for a very long reply ! Busy at work anyway to answer your questions: Tech found code P3190 engine failed to start, texh found throttle body have a lot of gunk build up. Tech cleaned the throttle plate rechecked and vehicle starts up. Tech re-program the engine and HV hybrid ECU to improve the vehicle condition as per tab.
  17. bisco
    49,392
    congrats!(y)
  18. Prodigyplace
    11,696
    11,318
    Central Virginia
    @danlatu Does this sound like an Oil Catch Can candidate?
  19. danlatu
    danlatu Senior Member
    533
    1,348
    maryland
    222k I would have to ask if the spark plugs were pulled at all, what do they look like? Does the engine knock at start up? Does your car consume oil? Check oil level every week and top off if necessary. Monitor how much oil is being consumed per mileage. What is your oil change interval? 3K/5K/10K? What weight oil? 5w20 5w30? I would pull the plugs as soon as the code pops up. Spark plugs will tell you why the car is misfiring. Are the plugs thick wet and shiny? Burning oil. (not in pics below) You can also look into the engine and see if wet oil is sitting on top of the pistons. Clean the entire intake manifold and follow the hose from the pcv valve to intake manifold. Replace the pcv valve and inspect the hose. If the pcv hose is wet with oil, I would put an oil catch can in. If the mechanic has all of this apart, I would clean the fuel injectors too. Not a fuel systems cleaner in tank, they need to be flushed with a machine. If the car has too much blow-by, an oil change/overfill could cause all of this oil to be pushed through the pcv and into the intake manifold. Once all this oil is in being blown in, built up into the intake manifold and settles. The next start up fouls the plugs along with engine knocking. Once an oil catch can is installed, check it in 250 miles. If there is very little oil/water/fuel in the can, recheck it at the 500 mile mark and so on. Every car will have different results as to how much blow-by, engine wear, outside temp, oil viscosity etc. During the summer (warmer climate) on a healthy engine, you can changed/emptied your occ every 5k miles and every week for winter depending on mileage and frequency of use. More cold start stops yield more moisture build-up in the crankcase. Check the catch can so there are no surprises along with checking oil level from dipstick. Make sure the occ is never more than 1/2 full. If it is full, it will just get sucked back into the intake and back to problem #1. If your car is consuming more than 1qt of oil in 600 miles, its time for another engine. If you bought this car from a previous owner, there is a chance they did not take car of the car. If a motor runs out of oil, the engine gets loud and the first thing you will here is a tapping noise coming from the head/valve train. If the car runs hot, the oil will break down and loose it's viscosity and engine will tap.
    Prodigyplace and Mendel Leisk like this.
  20. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Haven't heard of anyone installing an OCC on a gen2 before, is this a thing now ?
