  1. priusenjoyer101
    priusenjoyer101 New Member
    Yesterday
    Oregon
    My prius threw up code P0A93 (inverter cooling system performance) the other day. I noticed the tank for coolant was low near the inverter, topped it off, and drove for about 40 miles before the code turned off. 2 days later and not much more driving the red triangle appeared again. I haven’t been able to take it somewhere to test for codes, but the coolant looks fine now. When I was looking around under the hood I noticed frayed wiring coming from the sensor circuit breaker number 1. Looks like something chewed through it. Is it possible this happened that recently? Has anyone had experience with a similar wiring issue? How screwed am I? Picture attached
  2. Tombukt2
    Tombukt2 Senior Member
    9,366
    1,637
    Durham NC
    Yes that's a big problem You're going to need to get that unwrapped and straightened out pronto and see if there's any more damage look back by the HV battery the 12 volt battery anywhere you can see up under and around the dash have you found torn up napkins and things like that in the car You need to pull out the in cabin air filter behind the glove box Just squeeze and drop the box squeeze the tabs on the white tray and pull the panel out Is the air filter almost non-existent or all chewed up You need to get the shop vac with the computer tools and suck all that mess out of the air box this is very bad.
