Red triangle when turning left
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lpf, Apr 6, 2021.
  1. lpf
    lpf Member
    113
    33
    Greece
    When I'm turning left, above 60Km/h I'm hearing a noise from the right side. Yesterday red triangle turned on instantaneously, then turned off. Also, when I'm parking the car I hear noises when I'm turning the steering wheel, left or right. I'm thinking about stabilizers, torsion bar or something around there. Any suggestions on what to examine, welcome
  2. JC91006
    16,489
    8,402
    I would examine your engine oil level first
    jerrymildred and Raytheeagle like this.
  3. lpf
    lpf Member
    113
    33
    Greece
    Yes, checked, found at low level and topped up. Is there any way to check oil except the stick? Used to the dashboard dial in my previous car I do not remember to check oil...
  4. Leadfoot J. McCoalroller
    7,212
    6,774
    Pennsylvania
    2018 Prius c
    The driver remembering to check the dipstick is the primary method.
    A web forum reminding the driver to check the dipstick is back up #1
    Warning lights during left turns is back up #2
    lpf and jerrymildred like this.
  5. privilege
    privilege Active Member
    659
    169
    Birmingham
    about 25 years ago, I started checking the oil level at every fuel stop.
    if it drops enough between fuel stops to do damage, it's likely to have serious damage without the oil level being a concern ;-)
  6. jerrymildred
    jerrymildred Senior Member
    11,518
    14,122
    Tampa, FL
    The light means the engine has no oil pressure and therefore lubrication is reduced or gone. Metal on metal is really bad.
    I started checking the oil at every fill-up about 50 years ago when I got my first motorized vehicle. Years before that, I started looking both ways before crossing the street. Two very minor inconveniences with the potential to save a person a whole lot of inconvenience. ;)
    dolj and lpf like this.
  7. lpf
    lpf Member
    113
    33
    Greece
    Thanks, all posters, for solving my bewilderment. Really is very innovative way to check oil level, when cornering. And to get back to my first post here, the noise problem comes from the vertical stabilizers, which I will replace asap.
  8. jerrymildred
    11,518
    14,122
    Tampa, FL
    Well, not to put too fine a point on things, but people have been using this method to destroy engines for about a hundred years. :LOL:
    Glad you found the noise problem. (y)(y)
    lpf likes this.
