1. Teacherjoe
    Teacherjoe Junior Member
    29
    Yes, they are all on. I have the red triangle, the check engine, the brake, and the vsc lights on. I put in a new high voltage battery this past summer so what now? Any suggestions?
  2. JC91006
    16,827
    8,600
    did you put a brand new battery from Toyota? There could be many things that cause the triangle, but if you have a refurbished battery, that's where I would look first.
    #2 JC91006, Dec 4, 2015
  3. Patrick Wong
    18,210
    6,513
    Check the inverter coolant reservoir for fluid turbulence. If you do not see this, the inverter coolant pump has a problem.
    Make sure the 12V battery is in good condition.
    Get Mini VCI to read the DTC if there are no obvious problems that you can see and fix.
    52,385
    how many miles on her?
