Red Warning Light & Temperature symbol
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priori07, Mar 22, 2017.
  1. priori07
    priori07 New Member
    US
    Hello all.
    I have a 2007 Prius. I just recently got my error code p1121 fixed by having the coolant part for the engine replaced. Ever since, on and off I get the red triangle warning light and the temperature signal. All my fluids are topped off especially the antifreeze. Any conclusions ?
  2. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Did you bleed the engine coolant properly by cycling the CHRS pump and using the bleeder valve on top of the radiator?
    Does the cabin heat work properly?
    Are you checking the coolant level in the radiator or in the plastic reservoir bottle?
    Data Daedalus and valde3 like this.
