Reduce output power mensage
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Carlos campos, Jul 25, 2020.
  1. Carlos campos
    Carlos campos New Member
    Pensacola
    2016 Prius v wagon
    Hi guys, i'm New in Prius family. I owed 2016 Prius and i got this mensagem: reduce output power with yellow triangle. I need help, this car only have 34K Miles.
  2. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Welcome, Carlos. You either need a code reader that'll read Prius codes, or take it to a dealer to have them read it. Either one is cheaper and faster than guessing. It could be any number of things.
    krmcg likes this.
  3. Carlos campos
    Pensacola
    2016 Prius v wagon
    My mechanical pull a code PO6579E ( voltage "A" on the actuator locked in the on position), he used to work in Toyota shop but he cannot figure It out. I Just want to know before i take my Prius to Toyota shop. Someone know this code?
    49,501
    that's a throttle actuator power supply ecm problem. do you know the history of the car?
    Carlos campos likes this.
  5. Carlos campos
    Pensacola
    2016 Prius v wagon
    So problaly is the sensor locate on the throtle body? I dont have the history of the car but what i know is that i bought from a auction. The car was running i even drove for a minute in the EV mode and now the hybride os not charging
  6. Carlos campos
    Pensacola
    2016 Prius v wagon
  7. bisco
    49,501
    i think it is the ecm output voltage. any chance the car was flooded?
  8. bisco
    49,501
    is the mechanic following the troubleshooting in the service manual?
  9. Carlos campos
    Pensacola
    2016 Prius v wagon
    i just called a insurance company and found out that the car was flooded. i dont have idea what is the level of water because the car was very clean with no show of waterline. that any way the ECM output voltagem to be flash ?
  10. bisco
    49,501
    sorry to hear it.
    i don't know anything about it. your best bet would be tech stream and the service manual.
  11. Carlos campos
    Pensacola
    2016 Prius v wagon
    Hi guys, i took it off the ECM beside of fuse box ( motor compartment) and was damage by water, that i think was somebody try to car washer the engine and somehow got water inside the ECM and the plug. look the picture. i bought a used part with the same OEM number.
    i will put back together and reprogramming. soon i will tell what happens. thanks!!!!!
    jerrymildred and bisco like this.
  12. bisco
    49,501
    wow, i would never power wash the engine bay, good find!(y)
  13. Carlos campos
    Pensacola
    2016 Prius v wagon
    hey guys, just want to resume what happend to my car e how i fixed. as i show above the pictures, the old ECM was bad, so i bought a good used one, same part number and had replace and reprogramming. now the car runs fine, no lights on.
    Tip: Never try to wash the engine bay.
    jerrymildred and Air_Boss like this.
  14. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    What did you use to reprogram the ECM to the original VIN?
  15. David9962000
    David9962000 Member
    139
    66
    2020 Prius
    Where is the car from? I see it's in metric. Or how did you convert the temperature to Celsius?
  16. Carlos campos
    Pensacola
    2016 Prius v wagon
    The shop used the techstream program from toyota.
    Air_Boss likes this.
  17. Carlos campos
    Pensacola
    2016 Prius v wagon
    from Brazil, but you can go in the configuration icon and convert celsion to fahrenheit ou looking in the manual book.
