Refueling problem poll for all Prius owners
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by qbee42, Jun 30, 2008.
  1. I always have problems
    10 vote(s)
    4.8%
  2. I frequently have problems
    16 vote(s)
    7.7%
  3. I sometimes have problems
    18 vote(s)
    8.7%
  4. I occasionally have problems
    46 vote(s)
    22.2%
  5. I never have problems
    117 vote(s)
    56.5%
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    There have been long running discussions about refueling problems for the N.A. Prius with the fuel tank bladder. Let's see if we can get some real data about the problem.
    Tom
  2. tasker109
    tasker109 New Member
    147
    Illinois
    never....but we follow the guidelines regarding slow filling and not overfilling.
  3. freshmtt
    freshmtt Dachshund Addict
    532
    Chicago Suburbs
    Never, so far,, keeping fingers crossed.
    I usually fill up at 2 or 3 pips and can put 7 gallons in. I have never let it get down to 1 blinking pip as all the talk on PC has made me afraid to even try to get it down to 1 blinking pip. So, I am assuming that with 2 or 3 pips left I have around 1/4 of a tank about 3 gallons or so.
  4. Zhe Wiz
    Zhe Wiz Member
    128
    Ithaca, NY
    Two Prius family here - both 08's. Only occasional problem we have is pump shutting off too soon. Seems to be pump dependent though, and doesn't happen often.
    Zhe Wiz
  5. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I've never had a problem fueling up the old girl.
  6. charansr
    charansr Member
    107
    Concord CA
    Never had issues with the tank burping. However i cannot get more then 9 gallons in one shot.. and i never complain about it.
  7. judymcfarland
    judymcfarland Queen of Moral Indignation
    578
    Glendale, WI
    The only issue I've ever had is that if I put more than 6-7 gallons in, I have trouble getting the hose out of the filler tube when I'm done. It seems like Fiona wants to suck down every last drop. . .
  8. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I've always followed the "unofficial" guidelines of slow filling (usually set pump to first notch) and have never really seemed to have a problem until recently. I don't believe it to be any fault of the Prius, but rather the pump I suspect to have been the culprit however I've never been able to reproduce the situation at the same pump.
    I was filling at a pump (set to first notch as usual) and turned my attention away while filling and when I turned around at the sound of the pump shutting off it was reading 12.881 gallons!!! :eek:
    The bill was $45 when prior to that I had never spent more than about $33 on a tank of gas. I didn't have the time to argue with the station that my car only has an 11.9 gallon tank and I was driving to get there so yes there had to be some amount of fuel in the bottom of the tank so I wanted to know where the rest of it went? Suspecting I had been a victim of some scheme to rip customers off on gas I reported the station to Department of Agriculture - Weights and Measures who is going to investigate and test their pumps. Haven't heard anything back yet... Aside from that, no problems... So I selected "occasional" from the survey.
  9. misslexi
    misslexi Member
    130
    Renton, WA
    Only with older, mostly rural gas pumping equipment, never (yet) with newer pumps.
  10. jjksutton
    jjksutton New Member
    97
    Tampa
    I fill up full blast at 2 pips or less. When the pump automatically stops, so do I. No issues with either the 04 or 08.
  11. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I don't consider it a problem, I have never been able to put more than 10 gallons in my tank.
    The specs do say that the tank capacity is 11.9 gallons however that was before they put the bladder and enviromental stuff in it.
    I normally fill up when I get to 2 pips though ocasionally I have seen the blinking pip. I've never run out of gas.
  12. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I voted "I never have problems." But... there's always the next fill-up.
    I would have preferred to have this choice: "I have not yet had a problem,"
    which admits to the possibility that things might change in the future.
  13. Huntceet
    Huntceet Junior Member
    85
    Chicago area
    2018 Prius
    Ok, I've never had a problem fueling. But I've only got 4800 miles on the car. I just know that the next time I fuel up it's going to geyser all over the place. All on account of me replying to this poll.
    Rod
  14. qbee42
    18,058
    3,073
    Northern Michigan
    I like this answer. Here we have a car with as much technology as NASA, but it doesn't pay to tempt fate. :D Technology is like that. Even when you understand it thoroughly and use it all the time, it still feels like black magic.
    Tom
  15. doubleg2005
    doubleg2005 Member
    236
    i have twice. the first time i set it on the first notch and was cleaning the windshield when i heard and then saw gas spilling all over the place! apparently the shut-off never registered. the second time it was nearing 10 gal and i decided to manually shut it off to prevent a repeat of the previous event, causing the gas to burp back up a little... :(
    other than those two issues (the first at a Valero and the second at a Brookshire's) everything's been great!
  16. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Put one more choice there:
    It only happened once
    Ever since then I let the tank vent before fueling. Open up the gas cap..go inside..get soda...wait a little bit. And it then fuels up fine.Haven't had a gusher since.Fingers crossed. :fear:
  18. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Yeah my first was at 5500 miles. Was flawless till that event. Always on slow slow fill too. Man, almost a gallon of gas shot out of the tank. Now I have had good luck venting. Emphasis on luck.
  19. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    In two years I had one "no shut off" problem and one brief "premature shut off".
  20. dogfriend
    7,512
    1,185
    Carmichael, CA
    I have had 2 BGT (barfing gas tank) events in 20K miles. The last time it happened was over a year ago. In retrospect, both times may have been caused by not getting the nozzle far enough down into the filler tube. The tip of the nozzle must be below the rubber seal inside the filler.
