refuled then reset trip A and B, drove off and they are all different mpg's, A reading 5 mpg higher
Discussion in 'Gen 3 Prius Fuel Economy' started by priustexasbob, Feb 21, 2018.
  1. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    I refuled, reset trip A and B, went back to at start and drove away. I circled around from start to A then to B, they all read different start and B were close, about 1 or 2 mpg difference but A was off by 5 mpg. I figured they would be pretty much the same reading but why A was so much off was perplexing. I arrived at gym about 5 miles away, the difference from A to B was down to 4 mpg. why so much disparity? should they all not be about the same?
  2. Mendel Leisk
    40,586
    Going with just the text I've made bold: yeah I don't understand either, would think they should be the same. But: you completely lost me in the part that isn't highlighted.
  3. Threej
    Threej Member
    99
    99
    Portland, OR
    Like Mendel, I'm having difficulty reading the details of your procedure.
    However--
    In the first 30 seconds of a cold startup, my Prius drinks gas like a drunkard. If I started my prius, immediately reset trip A, and then took about 15 seconds to switch over and reset trip B, the amount of gas burned on trip A but not trip B in those 15 seconds would be noticeable, and would probably take a little bit more than 5 miles to average out.
    fuzzy1 and scona like this.
    51,155
    try the same 20 mile drive twice, after the car is fully warmed, and see how they compare. keep the same speed and acceleration as much as possible, the human factor and wind are the outliers.
  5. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    ok. the car was already warmed up and I refuled. after refueling I started the car and BEFORE moving even one foot, I reset both trip meters. then as I was driving I kept switching between the trip meters.
  6. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    oh man I fell like a dumbbunny - this was meant for the C chat which is what I own. I'm going to copy it there too or a mod can move it.
