Refurbish Traction battery after P0A80
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by a.mcintosh, Jun 27, 2022.
  1. a.mcintosh
    a.mcintosh Junior Member
    Terrell, TX
    2015 Prius c
    I have 2 refurbished modules (1 block) from eBay.
    I have the OBDLink LX and Hybrid Assistant (HA). I ran the battery test.
    I have a handy multimeter.
    I have worked with corrosive chemicals and lethal voltages in my workplace.
    The traction battery is out of the car and inside a safe work area. I have matched voltages between the HA and the multimeter, I have determined that the block closest to the fan is HA block #10, and the one closest to the orange safety disconnect is HA block #1.
    I am thinking of rebuilding it with the 2 highest voltage modules put as block 1, then the next 2 as block 2, and omitting the two modules with the lowest voltages. These 2 abandoned modules did not come from the same block.
    The spreadsheet is a Google Doc.
    I'll be starting the final teardown and rearranging while the community offers any wisdom.
  2. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    The challenge you face is your replacement modules need to be of similar age and capacity as the existing pack. I often caution against using two replacement modules in the same block, especially if they're newer and of greater capacity than the rest of the pack because your voltage difference between blocks will be more extreme. It's best to blend those 2 modules into separate blocks...
    a.mcintosh likes this.
  3. a.mcintosh
    Terrell, TX
    2015 Prius c
    I really need a step by step procedure. The youtube video of a Prius C battery teardown is from a slightly different model, and I really want to study the sensor wire removal before I produce an "oops."
  4. a.mcintosh
    Terrell, TX
    2015 Prius c
    I have rebuilt the battery, and have close to 1,000 miles on the rebuild. My gas mileage went from upper 40s to mid 50s. I have ordered 2 more modules from the same vendor.
    Roqu3 and bisco like this.
  5. bisco
    49,492
    congrats, well done!(y)
  6. a.mcintosh
    Terrell, TX
    2015 Prius c
    [QUOTE="PriusCamper, post: 3263256, member: 87188"It's best to blend those 2 modules into separate blocks...[/QUOTE]
    I agree. My process typically does that.
