refusal to renew insurance policy
Discussion in 'Prius PHEV Plug-In Modifications' started by Arthur, Mar 9, 2009.
  1. Arthur
    Arthur Member
    94
    55
    Corning, NY
    I heard a rumor that State Farm is going to start refusing to renew the insurance policy on any car that has had a plug-in conversion done to it. The reason supposedly has something to do with too many claims being filed on those cars. (I was unable to find out what kind of claims were being made.)
    Has anyone heard about or experienced anything like that with State Farm or any other insurance company?
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I can't find anything either.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Why don't you ask State Farm? You don't have to tell them that you already have the mod.
  4. Patrick Wong
    18,200
    6,474
    If you don't reveal the existence of a significant modification, and your car is damaged due to accident or you wish to file a comprehensive claim, don't expect your modification to be covered by the insurance policy.
  5. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Erie treats as a modification without a problem. I just gave them a copy of the receipt.
    ---Kent
  6. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    I have State Farm and they had no problem with it. No different from putting in an upgraded stereo.
  7. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    That was the same statement I got from Erie. It's just an upgrade.
    ---Kent
  8. Arthur
    Arthur Member
    94
    55
    Corning, NY
    It may have been a misunderstanding. I think there was some confusion between normal cars that have been converted into hybrids and hybrid cars that have been converted into plug-in hybrids.
    Lack of technology literacy can lead to communications errors.
  9. Patrick Wong
    18,200
    6,474
    Were you charged an additional insurance premium to cover your conversion?
  10. SueK
    SueK New Member
    Illinois
    To Arthur:
    State Farm believes in being environmentally responsible, and was recognized by Fleet Magazine in 2008 as having the 3rd largest non-governmental alternative-fuel fleet.
    State Farm does not automatically nonrenew hybrid auto policies that have the plug-in converter, but in case-by-case situations we may request further underwriting review.
    We encourage anyone interested in State Farm insurance to contact their agent for more information. If you’re not yet working with a State Farm agent, you may visit statefarm.com , "Find Agents Near You" section to locate an one in your area.
    Thanks!
    Sue K.
    Property & Casualty Underwriting - State Farm Insurance
  11. Arthur
    Arthur Member
    94
    55
    Corning, NY
    Sue,
    I'm glad you replied to my message.
    Your reply means one of two things. Either State Farm routinely Googles its own name to keep an eye on what people are saying about them, OR State Farm routinely monitors groups like Prius Chat to read about the potentially unsafe driving practices that group members are talking about.
    With that in mind, I'd like to provide a "guide to safe driving practices for the Hymotion Prius," based upon what I have learned with my Hymotion Prius.
    1) Never drive any car while the car is in neutral. I actually tried this for a short while (as a way to keep the battery from charging too much on the way down my hill). Then, I read that it is considered unsafe and, in some states, is also illegal. I have since come up with an alternate way of driving down the hill and staying in EV mode.
    First, I do what PeakOilGarage recommended. I start my car and wait for it to go into EV mode. (I don't have the CARB update.) Then, I switch off the Hymotion battery while I am still in my driveway. This still leaves the car in EV mode and allows me to use up some of the charge in the traction battery on the flat stretch before reaching the downhill stretch. Because of the terrain, my traction battery only goes down to about 50-55% before I start going down hill and charging it up again. If I don't run it down like this, it will charge up to over 80% on the way down the hill and a CCL (charge current limit) will kick me out of EV mode.
    Then, halfway down the hill, I turn onto a level side street that has very little traffic. I monitor my SOC gauge (ScanGauge) until the SOC gets down to its normal value of about 62%. Then, I pull over safely and put the car in park. I turn off the power, turn on the Hymotion switch, and turn the power back on. I've found that this is the simplest and safest way to get the Hymotion system back on without letting the ICE (gas engine) start up. Then, I pull out and turn right at the next corner to go the rest of the way down the hill.
    2) Never drive at unsafe speeds (too slow), just to stay in EV mode. I normally drive at about 29 mph, when the terrain is relatively flat. Fortunately, the speed limit is 30 mph for most of my commute. After stopping at a stop sign/light, I accelerate back up to speed at a rate that is perfectly reasonable and safe. Some people don't agree, but that's ok. They're entitled to their opinion.
    As I've said before, the steepest hills on my way home require me to go no faster than 9 mph, if I want to stay in EV mode. Part of this steep road has a 45 mph speed limit and is 2 lanes, with no passing zones. Fortunately, I work 2nd shift and am not coming up this road until about 11 pm. So, I often make it all the way up the hill (at speeds ranging beteen 9 mph and about 20 mph) with nobody coming up behind me. This is perfectly safe for 2 reasons. First, I use my flashers, which you should always do when you are going significantly below the speed limit. Second, there are no street lights. So, it is dark enough behind me that I can see a car's lights when they are still pretty far back (even around a curve). That gives me plenty of time to either speed up to a more normal speed OR pull over (if I happen to be near a place where that is a safe thing to do).
    The bottom line is that you should never get so hung up on staying in EV mode that you make unsafe decisions. You should always be prepared to accelerate out of EV mode when the situation calls for it. When I am going up my hill in the daytime, there is a lot more traffic. So, I don't use EV mode on the hill in the daytime.
    You should never drive so slowly that you disrupt the flow of traffic. If everyone is passing you, you're probably going at a speed that is too slow to be safe.
    Finally, you should NEVER try to drive on a freeway at 29 mph.
    3) Be very careful to keep your eyes on the road, not on your Prius monitor or ScanGauge. Once you are familiar with your displays, it is perfectly safe to use them while driving. Just use quick glances at the displays and avoid the occasional temptation to stare at a number, waiting for it to change.
    4) Be conscious of the fact that you are driving differently from the regular gas-hog. Other people may sometimes not expect you to go so easy on the pedal. Be sure to drive defensively and leave plenty of room between yourself and other cars.
    5) Be cautious about doing additional modifications to your car. Make sure that you fully understand how the mod will affect your car's safety and reliability. For instance, I started putting a very weak (battery-powered) thermal blanket in the back of my car, hoping to help my traction battery stay warmer. The goal was to be able to use EV mode when the battery would normally be too cold to allow it. Fortunately, the blanket was too weak to work at all. I have since learned that uneven heating of the battery can cause a serious reduction in its lifetime. A really hot blanket would be a really bad idea.
    I have considered grill-blocking with styrofoam pipe insulation. I even bought the insulation. At this point, the weather is getting warmer and I won't be trying it this year. The two main concerns with this are (1) that the insulation needs to be secured with zip ties or something so that it cannot fly out while you are driving and create a safety hazard and (2) that you have to closely monitor your engine coolant temperature and be prepared to stop and remove some of the grill blocking well before the engine reaches a temperature that could cause any kind of damage to the car.
    6) When your Hymotion system was installed, there were items (spare tire, jack, etc.) that were removed from their normal secure locations. If you still carry these items in your car, make sure that they are secured in such a way that they do not become dangerous projectiles in an accident.
    7) Does anyone else have any additions for my "guide to safe driving practices for the Hymotion Prius?"
    Arthur
  12. Halbert58
    Halbert58 New Member
    London
    I'm a newbie here. I have gone through your suggestions. Really good and acceptable. Thanks a lot for providing those.
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Thankfully, reasonable insurance companies exist to replace State Farm. I suggest quick calls to Amica, IDS and USAA (if you are eligible) for a start.
    I insure through IDS aka Ameriprise (used to be AmericanExpress) in New Mexico. Premium for my '04 Prius is about $40/month for a 250k/500k liability and collision with a $1000 deductible.
  14. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    In the UK some of the mainstream insurance companies (who match car model and makes to their database of the mainstream 90% of the market) won't insure kit or unusual cars.
    When I had my City El EV I found that many insurance companies wouldn't touch it with a barge-pole. I ended up getting Adrian Flux, who are specialized insurance brokers for unusual, classic, modified or kit cars.
    When I rang them up to tell them I'd done a DIY PHEV conversion on my Prius they didn't bat an eyelid. They were great!
    Try shopping around, and look for specialist kit car, hot rod, or vintage specialists.
    Nikki.
