regarding Amsoil Signature Series 0W-20
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kamrul, Dec 31, 2024.
  1. kamrul
    kamrul Junior Member
    99
    17
    Bangladesh
    I am thinking of using the Amsoil Signature Series 0W-20 engine oil for the first time. However, I would like your suggestion on which quantity to pick the Gallon Jug (3.78 Liter) or multiple Quart Bottles (946 mL each).
    The owner's manual says to refill 4.4 qt. (4.2 L) with filter or 4.1 qt. (3.9 L) without filter.
    I always replace the oil filter at every oil change.
    I have used only 4 L jugs from other brands in the past and could fill approximately 3.9 L because the mark on the dipstick gets near Full at that point.
    If it is necessary to fill more than what the Amsoil gallon jug contains (3.78 L) then I will buy 5 quart bottles. However for the latter, about two-thirds of the fifth bottle will be wasted :unsure:
  2. PriusCamper
    PriusCamper Senior Member
    12,807
    5,192
    Pacific Northwest, USA
    Looks like there's just more detergents in the oil that makes it super expensive. Probably not worth it. As in the least expensive full synthetic motor oil is going to be almost no different than the most expensive full synthetic.
    As for buying quarts versus a gallon the latter is cheaper than the former...
    Lastly, it says you need 4.4 quarts but it's very difficult to drain all the oil out of a PrIus. I usually start with 3.5 quarts and then run the engine and then check the dip stick. More often than not, that's in the middle of the range between high and low on the dip stick.
    I only fill to top of the range on the dipstick if the owner of the car doesn't check their oil level or bring the vehicle to me consistently.
  3. ASRDogman
    ASRDogman Senior Member
    7,618
    3,923
    Since both bottles are the same oil, get the one that cost the least.
    Do not over fill! Follow what Toyota says. They know their engine best.
  4. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Depends on your OCI and oil burning rate. I used redline and oci was 14,000 mi with the help of black stone oil lab’s guidance. Had about 40% left of the 5th quart bottle after drain and fill. In between the first initial fill and 14,000 miles driven, the last 40% of the quart was used to keep a consistent top off. Had it been 5,000 mi OCI, the last 40% would have been unused and no top off needed. When using top quality oil, you can go longer than most oil, but get an oil analysis just to be safe. I ran redline for 100,000 mi at least, then the prices were jacked up so now I’m on the purple studf
    #4 Grit, Jan 1, 2025
  5. kamrul
    99
    17
    Bangladesh
    Unfortunately, I do not have any such lab that does such tests on requests paid or unpaid. So, mostly I rely on the manual and change the oil around 5-6,000 kilometers ( 3-3.5K miles ) or 6-7 months whichever comes first at most.
    Which one is the 'purple stuff'?
  6. kamrul
    99
    17
    Bangladesh
    Yes, both are same oil just the difference is in the quantity.
    If I get the gallon then I'd be able to fill up to 3.78 L which is lower than Toyota's recommended 4.2 L with a filter and slightly lower than the max I have ever filled 4 L with a filter.
    I am wondering if it would be fine to refill up to a gallon ( 3.78 L ) even though it is lower than the recommendation and it might be around the middle mark on the dipstick. I haven't noticed any significant oil-burning issues yet.
  7. kamrul
    99
    17
    Bangladesh
    Amsoil costs almost the same as Mobil 1 where I live. I have used Mobil 1 in the past but the only concern is that it is probably not the premium Mobil 1 that is sold in the USA.
    However, these two and Ravenol are the only Group IV PAO-based 0W-20 engine oils sold around me. I am not really forced to pick a Group IV base oil though as I have used other Japanese and European brands in the past that are formulated from Group III base oils and fine to be called Fully Synthetic in the USA.
    Apart from the Group III and IV debate, the main reason of thinking of choosing one of the most premium brands is in this post.
    Thanks for sharing the insight you have experienced, I have found similar as well. Usually, I leave around 200 mL in the 4 L jug, that's about the middle or more between high and low on the dipstick, drive it for a few kilometers and park it for the night. If the level drops below the midline in the next morning then I would refill the remainder in the jug.
    I guess I would be alright to refill one Gallon jug which contains 3.78 L since I have not yet noticed any significant oil-burning issue on my Prius. I change the oil around 5-6,000 kilometers ( 3 - 3.5K miles ) or 6-7 months whichever comes first at most.
  8. ASRDogman
    7,618
    3,923
    You could buy 2 large ones. Then you'll have some to replace the oil that gets burned.
    Then you'll only need to purchase 1 the next oil change.
  9. kamrul
    99
    17
    Bangladesh
    I haven't really noticed any significant drop in the oil level after 6-7 months. 2013 with almost 135K kms (~85K miles)
    I don't know, is it fine to store oil once the cap is opened? Summer is pretty long, hot and humid where I live.
    ASRDogman likes this.
  10. ASRDogman
    7,618
    3,923
    Oil lasts a LOONNGGGG time. Keep the cap on and you'll be fine.
    It will EASILY last a year....
    kamrul likes this.
  11. johnHRP
    johnHRP Active Member
    645
    187
    KA, DE
    Excel
    Amsoil and Ravenol are PAO oil that are more stable than typical HC synthetic or group III Castrol, Total, or Shell. You can do 1 year/10k miles interval without problem with PAO oil. I clasifiy 3 grades of base oil that I may use:
    1. Group III or HC synthetic. Castrol, Valvoline, Mannol, Eurolube
    2. GTL (gas to oil) from Shell Ultra or Penzoil Platinum Ultra
    3. PAO group IV or group V Alkylated Napthalene or Ester oil.
    For instance, Castrol or Liquimolly 0W-20 have several choices and the price also difference. The one with Longlife 508/509 is much more expensive than the one with API SP (Asia and America cars).
    However, the other factor is the additives package and manufacturers have standardized test. For instance, API SP has 3 more test than API SN and Dexos Gen 3 is even has higher treshold to pass. You can see it in the main additives producer website. Relative Performance Tools
    Lubrizol is the one that supply additives and the inventor of ZDDP antiwear.
    If I were you @kamrul, I will stick with cheapest API SP I can find and do 5000 miles or 8000 Km interval. It will keep your car better and prevent the nutorious oil consumption later.
    For instance, Mannol 7722 508/509, It is HC synthetic but cost €68 shipped to home for 10L. But the API SP 0W-20 Mannol is much cheaper, only €40 for 10L. You see the difference is large. I had tried both of them and they are good.
    #11 johnHRP, Jan 3, 2025
    PriusCamper likes this.
