? regarding Prius battery in accessory mode
Discussion in 'Gen 3 Prius Main Forum' started by sjea0124, Mar 26, 2012.
  1. sjea0124
    sjea0124 Junior Member
    We are in the market for a Prius (this is not a deciding factor just curious) and a couple times a month we like to go to the local drive-in and have a fun family night. Our drive-in is more modern where you can listen to the movie through the radio and just wondering how the Prius works if we watch 2 movies in a night. As of right now we turn our car on a couple times throughout the night but confused as to how the Prius would work.
    Sorry if its a dumb question but this is something we have done for a long time and enjoy it.
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Accessory mode will auto shutoff after 1 hour to protect the 12v battery.
    You can simply leave the car in "on" mode and if the 12v battery gets too low- the gas engine will auto start up to charge the 12v battery then shut off once the 12v battery is sufficiently recharged. It's actually a pretty fool proof system- most other cars won't automatically start the engine if the battery is getting dangerously low but the Prius will if you leave the car "on".
    51,155
    ahhh, the drive-in in march. must be wonderful!
  4. pfjmarina
    pfjmarina Junior Member
    46
    Marina, CA
    I agree with ny_rob. Best thing would be to just leave the Prius in "ready mode" (i.e. on). The engine will start/stop as needed to keep the 12V battery charged and the radio would never cut out. The 12V battery in the Prius is small so you want to be careful of using it too much in accessory mode.
    I have a slow leak in one tire. Whenever I have to fill it I put the car in "ready mode" before plugging in the air pump to insure that I don't overly drain the 12V battery.
    Haven't been to a drive-in in decades!
  5. sjea0124
    Thanks for the replies!
    Not rubbing it in but it is nice living in FL and being able to go to the outdoor all year round. Cheaper than taking a family to the theater and our drive-in has HD screens and projectors!
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    as people have kinda stated.. never keep the car in any mode other than READY for long period of time as you'll be asking for 12v battery problems sooner than later (if you drain the 12v at any time, consider it dead... recharge helps but the way the battery is, it's dead once drained.. or at at least extremely unreliable)
    sitting with the car in READY tends to only burn a gallon every 10 hours or so... possibly a little less time or a little more depending on volume used.. if a/c if left on.. etc..
  7. RaZa
    RaZa Member
    480
    93
    removed
  8. sjea0124
    The one we go to is in Lakeland between Tampa and Orlando called Silvermoon Drive-In
    iPhone 4 ?
