Regarding the hybrid battery...
Discussion in 'Gen 2 Prius Main Forum' started by jimnvicki, Jan 23, 2010.
  1. jimnvicki
    jimnvicki New Member
    Redlands, California
    Simple question: will the prius run without the hybrid battery or if it completely fails?
  2. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Yes but I imagine it will get <10 mpg because there isn't enough engine power to compensate.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I believe if the traction battery dies, there is no power to available to make MG1 spin and then the gasoline engine cannot be started.
    Which means, no, the car will not run w/o the hybrid (traction) battery.
  4. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    That is my understanding as well. The ICE has no starter (in the traditional sense).
  5. spinkao
    spinkao New Member
    316
    76
    Czech Republic, EU
    No, it won't. No way to start the ICE without the traction battery, as it is spun by MG1 (as others stated before me).
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I also believe that without power to MG1 or MG2, the ICE will be in neutral and unable to move the car. It needs to push against something, as it is not directly attached to the wheels.
    A simulation of Prius's Planetary Gear
  7. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Jimbo, Thanks for that planetary gear sim. cool. Regarding the original question, all above is correct and the only thing I would add is the fact that without a traction battery, the system will have DTC's up the yingyang, and will probably disable the car from even moving. You'd be lucky if you would even able to get it out of park in that situation...just my 2c.
  8. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    My SWAG is that, no, the car will NOT run if the hybrid battery is COMPLETELY DEAD.
    The system REQUIRES the battery to provide power in even low load situations to provide torque to MG1 while the engine spins. I could be wrong, but the system works by balancing torque, and sometimes MG1 gets driven (generating power) and sometimes it has to push, too.
