Regen braking - when does friction kick in?
Discussion in 'Prius c Technical Discussion' started by AWDstylez, Jul 12, 2012.
  1. AWDstylez
    AWDstylez 500hp to 99hp
    66
    38
    Just a quick question...
    Am I correct in assuming that during braking the vehicle is using primarily the regen braking at any point short of the "charge" meter being pegged?
    Sometimes it feels like this is true, but others it doesn't, even at the same speed. I know that friction brakes will be used regardless at low speed, so we can ignore low speed stops for this question.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The Prius tries to use regen as much as possible. The exact details may vary with your newer Prius, but in general here are the limits:
    1) Speed. At low speed MG2 rotates too slowly for effective regeneration, so the Prius transitions to friction. This happens at around 7 mph with the Gen II Prius.
    2) Capacity. Regeneration is limited by the ability of MG2 to produce current and the ability of the HV battery to absorb the current. Heavy braking or a high SOC on the battery will limit the amount of regen.
    3) Loss of traction. If either of the front drive wheels loses traction, the Prius immediately transitions into ABS friction braking.
    4) Panic stop. If you mash the brakes, the Prius assumes that it is a panic situation and goes directly to friction braking with brake assist.
    Tom
    AWDstylez likes this.
  3. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I saw somewhere that there are varying hydraulic pressures to the pads. These pressures would be applied at the point the controller brain thinks they are needed.
    I only saw a small handful pressures, though the actual pressure(s) may be much more variable.
