Regen: the AER booster
Discussion in 'Prime Fuel Economy & EV Range' started by Tideland Prius, Apr 3, 2019.
  1. Tideland Prius
    16,125
    Up til now, we’ve only had the leaf cars or “E” squares to indicate regenerated energy (in 30 or 50Wh chunks... although I guess you could get half a leaf car or an E square).
    Buried in the Energy Monitor screen of the 11.6” version, is an actual readout of the total regen amount per trip as well as regen per minute.
    I took a 39km trip (almost 25 miles) and documented the data. I regenerated 1.36kWh over the entire trip or about 25% of the actual battery capacity for the EV portion.
    Below, you can see that I travelled 39.3km (24.6 miles) and the daily average is 12.1kWh/100km (5.17Wh/mile). I did the trip in the evening so it was cooler (14°C/57°F).
    There’s 24% SOC left....
    .... with 12.3km (7.7 miles) of range left.
    Doing the math, it’s close to 50km/30 mile range.
    12.3*(1/24)*100 = 51.25km
    12.3 + 39.3 = 51.6km
    So if I did my back-of-the-napkin math correctly, I roughly regenerated 11-12km (~7 miles).
    benagi, jerrymildred, fuzzy1 and 3 others like this.
    49,371
    wow, that's huge! was there a lot of downhill?
  3. Tideland Prius
    16,125
    No but there was a bridge with a decently tall arch to it. It was all city driving.
    49,371
    i've never regened even one mile in the pip, that's quite an improvement.(y)
  5. Tideland Prius
    16,125
    The regen in the Gen 4/Prime is quite good. We have the Gen 4 with the Li-Ion battery as well and the battery charge fluctuates quite a bit more than the NiMH of the old Prii. It's more eager to use the battery and go into EV mode because it's much better at recapturing energy and topping up the battery.
    kevin.c likes this.
  6. bisco
    49,371
    they must have been conservative with regen on the pip, their first foray into lithium in n/a.
  7. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Last summer, in the Smokey Mountains, we regenerated the whole EV range on our PiP and ran out of battery capacity. More than once!! Not much regen here in FL, though.
    However, I've noticed also that the Prime seems downright eager to regenerate and to run in EV even when the EV range is depleted.
  8. bisco
    49,371
    i'll be interested to see if anyone can come close to duplicating tide's city driving experience. don't recall reading anything near to it.
    agree on the pip, never regened back into ev on flattish land.
  9. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    In the city every time you come to a stop it's a significant amount of regen. And every time you accelerate it uses a significant amount of energy. That averages out, so the total range is still 25-30 miles.
    In other words, if for some reason you only had friction brakes, you'd get more like 18 miles of range. That's how hybrids work, and that's the main reason why these are so much more efficient than non-hybrid gars. Regen works about the same way in EV mode as in HV mode.
    I have charged the battery in mine about 80% by driving down a long hill (Mt Evans). It takes a long gradual hill at low speed, otherwise you'll pass some kind of limit and it will go into engine braking mode. On that trip I started at the top of the mountain in HV mode, and from there I drove 60 miles in EV mode just using recovered energy. Of course it took some gas to get up there.
  10. Gen3PP
    Gen3PP New Member
    29
    Maryland
    Compared to my Gen 3, the Prime tries to charge at almost any time it can. Cruising at 50 to 60 it is always charging at least a little for later EV stretches. I do not believe this is efficient
  11. bisco
    49,371
    that doesn't jive with tidelands figures
  12. jerrymildred
    11,508
    14,109
    Tampa, FL
    What anyone believes is irrelevant. The fact is that the Prime gets better fuel economy than any other Prius except the Eco. My Prime will put itself into EV mode for a mile or more at a time at 60+ mph and then charge back up again.
    My PiP was always going back and forth with charging and using the battery (without actually shutting off the ICE) at highway speeds in HV. All three of our Gen 2s do/did so as well. You can see the energy go back and forth on the display.
  13. Gen3PP
    Gen3PP New Member
    29
    Maryland
    I am trying to point out that there may be room for improvement in the algorithm of when and how much to charge the battery. Is the Prime optimized for the unskilled driver or the experienced hyper-miler? The fact that we must always remember that we have to push the hybrid mode button at start up every time to conserve battery for latter short EV trips(no ICE warm up) must tell us something. They are more interested in the unskilled test driver for the EPA that will produce the highest MPG without thought.
  14. jerrymildred
    11,508
    14,109
    Tampa, FL
    I would be absolutely stunned if someone improved that algorithm as to when and how hard to charge the Prime's battery. The intention is to run the engine at its most fuel and emissions efficient rpm and use any excess power generated to charge the battery or for the battery to help the engine if that rpm is not enough to meet the driver's demand.
    AFAIK, all Prii are optimized for minimal emissions and since 99.999% (or something like that) of trips are beyond the EV range of a non-plugin Prius, the car assumes you'll be needing the engine and starts it up unless you tell it otherwise.
    Most trips for most people in the Prime are within battery range and so you need to tell it if you don't want to drive on battery. Over 90% of my miles are EV miles. I don't want to have to warm up the engine 20-40 times a week when I only need the engine a couple times a week. That would cost money and increase emissions.
    Would you rather push that button 99% of the time when you start the car or 1% of the time?
    Prodigyplace and Prius from Dad like this.
  15. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Once the engine starts, the Prius family keep the engine running so i reaches it optimal low polluting temperature as quick as possible. I think that is why on the Gen 4, the heater causes a bigger MPG hit than the electric Air Conditioner.
    Tideland Prius and jerrymildred like this.
  16. Gen3PP
    Gen3PP New Member
    29
    Maryland
    I feel like I am being trolled.
  17. Tideland Prius
    16,125
    Your Gen 3 does the same.
    jerrymildred likes this.
  18. jerrymildred
    11,508
    14,109
    Tampa, FL
    I'm sorry, that wasn't my intention. I just wanted to make sure you understand the reason the car acts the way it does. My intentions are friendly. I never troll.
    Prius from Dad and Prodigyplace like this.
  19. bisco
    49,371
    c'mon jerry, we all know your m/o :cool:
  20. Gen3PP
    Gen3PP New Member
    29
    Maryland
    Yes, but how much regen load is on the ice is the big difference (40 mpg(PP) vs 60mpg(gen 3) showing on the ice meter) most of the time (flat roads 45 to 60mph). My use case is almost no charging availability and long trips. If you are plugging up all of time, you may see almost none of these things.
