Regen under 30mph
Discussion in 'Gen 2 Prius Technical Discussion' started by Path2ground, Jul 22, 2006.
  1. Path2ground
    Path2ground New Member
    I am unclear about regenerative breaking at speeds between 30 and 7 mph .
    Is there a point that regen becomes uneffective under 30mph before the friction pads engage at 7 mph?
    I have seen something about this lately, but can not find the info again.
    Thanks ahead for your responses
    David
    06 Seaside Blue pkg#6+Tint
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I don't have a definitive answer for you but based on what I know I would say that most likely it's maximum generating capacity does fall off as you go slower. At just above 7 MPH there may not be much generating capacity left and that's why it shifts to the friction brakes. Maybe someone with instrumentation such as CAN-View will be able to provide a good answer?
  3. whodat
    whodat Member
    117
    Aptos, CA
    <div class='quotetop'>QUOTE(tumbleweed @ Jul 22 2006, 11:32 AM) [snapback]290558[/snapback]</div>
    And lets hope that the same result for older than 2006 models are the same for the 2006 Prius. Can-View is not yet availalble for the 2006 Prius.
    With that said, I will be interested in seeing the Can-View results.
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    the amount of current that gets generated and sent to the battery drops down to probably about 6 amps just before regen drops and the friction brakes get used. At 30 mph/50 kmh about the max you'll see is about 80 amps maybe a bit more but if you press to hard and go thru the stroke simulator on the brake controller you get friction brakes and regen.
    On the Classic I get at 30 mph/50 kmh about 45 amps dropping to about 4 amps as the regen drops off. The values for the 2k4 2k5 and 2k6 should all be the same as the system hasn't changed.
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    What Tumbleweed and Frank are saying, David, is that you get some regenerative braking right down to the point the friction brakes take over. You generate more electricity when you have greater kinetic energy (forward motion) that the motor/generator can use. When you are moving fairly slowly, around 7 or 8 MPH, the forward motion doesn't generate much electricity and friction braking provides a smooth stop.
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    My regular mechanic did my 30K check up and suggested that I might want to use my brakes at least once in a while they had rust on the drums and disks! Pad ware, he called it 90% but told me unused was closer to the truth! How about pads every 250K?
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    you can get very high regen numbers even at low speeds on steep hills. i now live on the side of a hill and will hit 80-90 amps even at speeds as low as 20 mph (have to brake firmly to keep speeds within reason which is about 15 mph)
  8. Bill Merchant
    4,096
    81
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Jul 22 2006, 07:54 PM) [snapback]290748[/snapback]</div>
    It's all about energy conversion. High speed and flat, car has velocity kinetic energy to convert to electrical energy. Going down a steep hill, potential energy of acceleration of gravity can be converted to electrical energy.
    But energy conversion is always less efficient than direct use. It takes energy to accelerate on the flat before you slow down, it takes energy to get up the hill before you come down. A Prius is more efficient than a conventional car because it captures some of the energy a conventional car just turns into heat in the brakes. Entropy rules!
  9. Frank Hudon
    4,147
    a week or so ago I was on the down hill to work and had it in B and a bit of brake and was regening 53 amps and the traffic sped up so put it in D and without modulating the brake all I was getting was 19 amps. Same speed same brake pressure just the difference between B and D. Go figure. Made a mental note as it was supposed to be the other way around.
  10. porschett
    porschett New Member
    16
    San Diego
    BTW, how do you guys know how many amps you are regenerating? Is there a screen setting that tells you?
  11. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(Porsche403 @ Jul 23 2006, 12:18 PM) [snapback]290966[/snapback]</div>
    One (hyphenated) word: CAN-view
  12. porschett
    16
    San Diego
    <div class='quotetop'>QUOTE(Betelgeuse @ Jul 23 2006, 11:22 AM) [snapback]290969[/snapback]</div>
    Bummer, it's not available for 2006.
  13. Path2ground
    <div class='quotetop'>QUOTE(Bill Merchant @ Jul 23 2006, 02:52 AM) [snapback]290856[/snapback]</div>
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Jul 22 2006, 10:54 PM) [snapback]290748[/snapback]</div>
    Dave and Bill,
    First I would like to thank everyone for their knowledgeable input.
    I would like to add a twist to the downhill senerio, Dave. Is there a change of charge rate based on the SOC level? I drive in the blue ridge mountains and valleys daily and sometimes I can charge two to three lines in one breaking, at other times, with simular breaking pressure and distances, I am lucky to gain one bar. As long as I'm in the middle to low end of the SOC level, I notice a good charge rate, but if I am at the top of the blue on the SOC, I am lucky to get into the green. I have only achived a full state once since purchasing the Prius in May. Its looks like a combination of events that cause this, huh?
    I may install a clamp on amp meter and build a spreadsheet for all of the system deviations during the regen process. I will certainly share the information when this comes together.
    Thanks again.
    David
  14. whodat
    whodat Member
    117
    Aptos, CA
    <div class='quotetop'>QUOTE(Bill Merchant @ Jul 22 2006, 11:52 PM) [snapback]290856[/snapback]</div>
    Hi Bill,
    In theory what you say is true. My guess is the regenerative brake uses magnetic coupling and the magnetic flux versus current curve is generally not linear for magnetics and as such there may be a sweet spot for current generated versus speed going down hill. Until I get a CAN-View for my 2006 Prius I will have to rely on data from others regarding this. And this stil obeys conservation of energy. And increasing entropy.
    BTW, all this ignores the SOC of the battery as there may be some other effects regarding the charge controller limits as a function of the battery charge.
  15. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    SOC clearly has its influence on the system. Battery temperature is also an important factor.
  16. DaveSheremata
    DaveSheremata New Member
    249
    Arlington, Virginia
    Hi David
    Note on these diagrams that the state of charge is not reflected in a linear fashion, as detailed on this page:
    http://privatenrg.com/#terrainfollowing
    So, the actual SOC may not have as large an impact on regen as it appears... of course, it also might! The CAN-view can more accurately display the SOC than the MFD, from what I've heard... I can't wait till they come out with a 2006 compatible version!
    Dave
    <div class='quotetop'>QUOTE(Path2ground @ Jul 23 2006, 07:53 PM) [snapback]291151[/snapback]</div>
  17. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(Porsche403 @ Jul 24 2006, 07:02 AM) [snapback]291108[/snapback]</div>
    You can make your own SuperMID C-1. :)
    http://priusdiy.fc2web.com/C-1.html
    (Sorry in Japanese only. The Babel Fish site maybe help you to translate.)
    Ken@Japan
  18. Path2ground
    <div class='quotetop'>QUOTE(DaveSheremata @ Jul 24 2006, 01:48 AM) [snapback]291328[/snapback]</div>
    Thats alot of information, it sure explains the difference between the lower and upper bars.
    Thanks!!
    David
