Regenerative brake malfunction?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Christian_cool, Feb 12, 2015.
  1. Christian_cool
    Christian_cool Junior Member
    92
    17
    Germany
    Hello again Everyone. I have a question regarding to the regenerative brake.
    The story is this night i was driving home from my friends place at night only 4 km away from my home and the outside temp was +2 degrees Celsius.
    Half the way is kinda going downhill so I use the normal foot brake to take the speed from 50 to 30 km/h since its not permitted to drive faster, and then suddenly when i brake i can hear the engine running at high RPM and when i keep eye on the Eco bar acceleration it shows zero regenerative charge, and the battery was only half full.
    Normally i use B (engine brake) only at the steep hill, so since the engine was slowing my car so much down in speed i didn't use it.
    So i drive more around in the city to let the car warm up, and it didn't help.
    I experienced this for third time now in the winter time. Is this a fail in the cars system, or it can be normal behavior in special conditions ?
    Its a Prius 2010 with 148.000 km on it.
    thanks for any advice and help :)
    #1 Christian_cool, Feb 12, 2015
  2. Former Member 68813
    3,524
    983
    US
    maybe the battery was too cold to accept that high charge safely?
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    You can select B mode at any time, but the computer will use the same engine braking anytime it wants to do braking but has no excess battery charging capability. I know there are limits to how much you can charge a cold battery.
  4. Mendel Leisk
    40,582
    It sounds like it's in B mode, without you choosing it.
  5. bisco
    51,154
    whats that in farrenheight?
  6. mrbigh
    3,686
    699
    Long Island, NY
    The same temperature, COLD !!!
  7. Mendel Leisk
    40,582
  8. bisco
    51,154
    never seen the engine burn off charge with a half full battery at that temp.
  9. Christian_cool
    92
    17
    Germany
    Thanks for your replies :)
    I drove again the same route last night and it didn't act like that. I think Either the battery was to cold, or it was a software glitch.
    If it happens again i will post a update and take it to the dealer and see what they say, but since it is out of warranty, no matter what it will cost me $$ if they want to check or do repair.
  10. A617
    A617 Member
    213
    95
    OKC, OK
    As long it dose not throw a check engine light or a Check hybrid system, don't worry about it, and resume driving.
    Christian_cool likes this.
  11. bisco
    51,154
    probably a windows bug.
