Regenerative brakes versus friction (regular) brakes
Discussion in 'Gen 2 Prius Main Forum' started by impreza, Apr 6, 2004.
  1. impreza
    impreza New Member
    33
    Lincoln, RI
    It seems to me that one of the best ways to save energy is to NEVER use of the friction brakes, if safely able to.
    I figure that if you can use the brakes in such a way that ALL of your forward enertia gets converted into electricity to recharge the batteries, and NONE of that inertia is wasted in heating the brake discs, then I've braked successfully. I've succeeded in minimizing waste since the energy that heats the brake discs/drums is just wasted energy.
    And I've found that if I anticipate the stop soon enough, I rarely have to press all the way down except at the last second to get the car to totally stop. However, I really am not sure when I'm maximizing use of the regeneration and NOT using the metal to metal friction brakes.
    I've found that pressing lightly on the brake does cause some drag and I'm sure that that is the regen brakes. I can increase that pressure and I then feel a bit more drag and more brake pressure/more drag. However, I'm not sure when I reach that point when that drag is no longer from the regen brakes and is instead from the friction brakes.
    Is there a way to know for sure? Can I teach my foot to FEEL the difference? Maybe there is a sound that I could try to seek out? Maybe there is a point where the drag gets more abruptly different. Too bad there isn't some kind of light on the dashboard.
    Can anyone tell me (reliably) how to tell when I'm using the regen only and not yet down to the friction brakes?
    Thanks.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    At anything less than 8mph you're using friction brakes.
    Other than that, no, I can't tell you how to reliably tell. I will tell you that the graphs I've seen suggest that it requires very firm/hard braking to engage the friction brakes.
    Coastal Dave has announced that he will be releasing an engine/brake indicator for the '04 Prius. This will allow you to see when the ICE is running and when you are using your friction brakes. Should be a very useful tool for all of us and I'm eagerly anticipating it's release.
  3. Jonathan
    Jonathan New Member
    74
    It dawned on me today that anytime we're in regen braking only, we are only being slowed down by the front wheels, not all 4 as when traditional brakes are applied.
  4. m4prius
    m4prius New Member
    59
    Ohio
    Too bad Toyota does not show Regen vs Friction brake iindication on the graphic display. Would be a nice feature.
  5. rflagg
    rflagg Member
    947
    Springfield, VA
    This is one feature I'm very excited about Dave offering at CoastalETech.com. It's one of only a handful of things I think that should be included with the car that weren't. Hopefully Dave's mod is affordable and easy to install! :)
    -m.
  6. impreza
    impreza New Member
    33
    Lincoln, RI
    This is not really a big deal. In any braking, the overwhelming majority of the braking power is in the front wheels 24/7 anyway. That's why whenever a car is sold with "disc brakes", but not 4 wheel disc brakes, the discs are always on the front. The back would remain drum brakes because they simply do less work. It's just physics.
    The only problem might be if you are on ice and you use the front wheels only and they start slipping due to lack of traction.
    But the Prius has antilock brakes. So if the computer senses the front wheels slipping, it will use the back (friction) brakes.
    >>> I've made an assumption here that the anti-lock properties of the brakes are also in play for the regen brakes. If they are not, then this is indeed a flaw drivers need to be aware of. If someone is stopping slowly and only using the regen brakes and they start to slide, they might be inclined to let up on the brakes. But what they SHOULD do is press down harder so that the antilock system gets engaged. That would stop the sliding. I want to thank Jonathan for making me think of this.
  7. xlarimer
    xlarimer New Member
    135
    berkeley, california
    Dumb question when reading this thread:
    Does this mean that we won't have to replace our brakes as much if we use regen more than friction?
    First, my service tech says that I don't have to replace the oil as much (since it runs less), next I learn that there is no steering fluid to deal with.
    This is working out to be one of the BEST car ever!
  8. mboileau
    mboileau New Member
    278
    SF Bay Area
    I pulled out my hardcopy of the Toyota THS II Technical Spec. This document is worth its weight in gold. I got a copy from my boss who I believe purchased and downloaded it from the Toyota technical site. I'd really like to see this document in the Files section...
    Anyways, the spec shows two torque curves side by side, comparing the THS I system (in the 01-03 Prii) to the new THS II system. In THS I, there was always some hydraulic braking coming into play to supplement the regen braking. A slight tap on the brake pedal would first engage the hydraulic brakes, and then use regen braking upon further pedal depression. In THS II, the regen braking power range has been greatly expanded so that now it is almost exclusively the only means for braking. If I interpret the torque curve literally, in THS II the hydraulic brakes ONLY engage upon fully depressing the brake pedal. Anything short of that will exclusively regen brake. Note that the braking system, as controlled by the ECB module, is activated by a brake pedal stroke sensor, which trips any time you touch the pedal.
    Given all that, unless you're a complete digital driver (full accel, full brake only), your brakes and pads should last an incredibly long time!
  9. rflagg
    rflagg Member
    947
    Springfield, VA
    Also, According to the 2004 New Features Manual:
    The engine coolant in the '04 is most likely the Toyota Genuine SLLC (Super Long Life Coolant), which is pink in color. This fluid does not need maintenance on it until the car reaches 100,000 miles for the first time, and then subsequently every 50,000 miles afterwards. In the 03, it was every 30,000 miles or 24 months, whichever comes first.
    -However, it does state that it's possible that the car does have a mixture of the two, which means maintenance after 30k or 24 months. Does anyone know how to check and see what coolant you have in your Prius?
    -m.
  10. toyoprius
    toyoprius New Member
    109
    Boston
    If you car has been sitting a while after a rainstorm, you can usually hear the brake pads scraping away oxidation on the rotor. It's a mild grating sound that disappears quickly. However, you can use these opportunities to "test" the point at which the friction brakes engage. With your Prius in stealth mode (the EV switch is great for this), you can clearly hear the point at which the "humming" of re-generation gives way to the "grating" sound.
    Surprisingly, it takes more pressure than I would have guessed to engage the friction brakes.
  11. randalla
    randalla Member
    370
    Lexington, SC
    I plan on sticking pretty close to getting the oil changed every 3 thousand miles or so just to stay on the safe side. The ICE in the Prius cycles on and off so much that on shorter trips, it may not have enough heat built up in it to burn off condensation that forms in the engine.
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The '01-'03 had a 7500 mile oil interval due to reduced RPM and usage. When oil change time comes around, the oil is still a medium brown, not dark like from a conventional ICE.
    As for brakes - some have reported being as high as 100k miles on original pads w/ the classic. If you use regen wisely, the '04 may give the same.
  13. jasond
    jasond New Member
    165
    Boston
    The car's manual says every 5000 miles, and the car itself will remind you every 5000 miles. That's the "safe side" number. 3000 miles just keeps the profits high for the oil change folks, really.
    The manual also says that the car should use 87 octane gas, but I'd be willing to bet there are a lot of people who use 89 or 93 "just to be on the safe side" even though they have no idea what that would keep them safe from...
  14. randalla
    randalla Member
    370
    Lexington, SC
    Being a loyal viewer of MPT's Motorweek TV show for 20 plus years, I've picked up a number of helpful hints from their resident mechanic Pat Goss. Not that he is the final word on what is absolutely right for anyone's particular circumstance, I find that his advice will pretty much apply to the mainstream driving public. He has said numerous times on Motorweek as well as on his local radio show that the oil itself doesn't lose it's lubricating ability with mileage, it's the fact that the additives diminish with time, use and mileage and eventually cease their effectiveness as you put on the miles. 3000-3500 miles for city/suburban area driving has been his recommendation for oil change intervals and the logic in his explanations make sense to me. :)
    MPT's Motorweek: http://www.mpt.org/motorweek/carcare.shtml
  15. twindad
    twindad New Member
    60
    Lake Forest, CA
    Disclaimer: I DIDN'T TELL YOU TO DO THIS
    But...
    I found that after a typical drive without too many hills, I can touch the front discs and not get burned. In fact, on some occasions, they are only mildly warm.
  16. richard schumacher
    7,663
    1,038
    United States
    Simply because of the further refining required higher octane gas usually has less sulfur in it, roughly 100 ppm versus 200-300 ppm for 87 octane. This means it is somewhat less polluting. I use 93 octane when explicitly low-sulfur gas is not available.
  17. Batavier
    Batavier Member
    442
    The Netherlands
    Indeed, in the Netherlands the cheapest gas has octane 95 (Euro 95 it's called) and we also have 'Super' which has 98 octane.
    Shell just introduced Shell V-Power ™, it can be used in cars that normally tank Euro 95 and it has no sulfur in it (according to Shell). Actually if you read more on this 'amazing' fuel, it has less than 10 mg of sulfur per kilo gas.
  18. sibtrag
    sibtrag Junior Member
    44
    New York State
    Partly a safety issue. It would tend to distract you during braking, which is a pretty dangerous time. Especially if the car in front has ABS or suddenly increases its braking force.
  19. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I wonder what dash-display lawsuit has tainted Toyota's view of what we can look at. If it's so darn distracting, why can we look at ANYTHING?
    They should go back and put in a two-stage powerup sequence.
    1) Foot on brake and push Power button.
    2) Read the "Nothing I see on this screen will distract me, I swear!" message on the screen and hit its OK button.
    3) Car activates, you drive off.
    That way, we could have radio station messages and all kinds of stuff, without being baby-sat anymore. I mean, really, isn't what's already there fairly distracting, if you LET it be?...
  20. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    That's one thing I really like about the Acura Nav system compared to the Toyota one.
