regenerative braking in neutral?
Discussion in 'Prime Main Forum (2017-2022)' started by MNdriver, Aug 17, 2017.
  1. MNdriver
    MNdriver Senior Member
    549
    577
    I have a quick, naive question.
    As an experiment, this morning I shifted into neutral for long glides and while going down hills. I noticed that when braking in neutral, the monitor didn't register any regenerative energy going to the battery. Is this because regenerative braking doesn't happen in neutral, or just because the monitor (the EV one with the blue rainbow) won't display it when you're in neutral?
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    In neutral, you get only friction braking, no regeneration.
  3. MNdriver
    549
    577
    Thanks, Lee Jay.
    49,506
    you can feel the change when you switch, the car takes off like a rocket!
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Neither Motor/Generator is electrically active in N. This is why there is no regeneration in N and why so many who try to go through a car wash in N fail.
    If at all possible, never use N. Toyota is required to offer an N, there are very few times you should use it.
    (if you wish to 'clean' the friction brakes, stopping in N will do that)
    WilDavis and joachimz like this.
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    fail what? fail to get their car clean?:confused:
  7. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    They find their traction battery suffers serious depletion. :(
  8. priuscatprimeguy
    2,730
    2,640
    huh.....that's news to me. My EV range before and after never budges.
  9. Lee Jay
    5,850
    4,024
    There's no other choice. You can't put in in Park because it won't go. You can't put it in Drive because it will drive off after it gets to the end.
  10. Prodigyplace
    11,696
    11,318
    Central Virginia
    We are referring to the car washes where you are supposed to put your car in Neutral and the car wash pulls the vehicle through the different stations.
    The ones here tend to be where you stop your car within a certain area and the wash station travels around/above the vehicle.
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    And that is because Neutral disconnects ALL of the drive mechanism from the wheels; that includes the MG that does the regen.
    It is designed that way on purpose.
  12. Sam Spade
    2,036
    1,023
    2017 Prius c
    There is another long thread on here about that.
    ONE owner found that his HV battery level went down while doing that.
    He then found out that it would NOT do that if he turned off the electrical accessories......mainly the A/C.
  13. bisco
    49,506
    it's not an issue with plug ins.
  14. priuscatprimeguy
    2,730
    2,640
    ahhhh, plug in's, gotcha(y) golly, it's been 5 years since I drove a Hybrid (non plug in of course)
    #14 priuscatprimeguy, Aug 17, 2017
    joachimz and Prodigyplace like this.
  15. priuscatprimeguy
    2,730
    2,640
    yup, I go to the car wash that pulls the vehicle through different stations.:cool:
  16. Lee Jay
    5,850
    4,024
    No it doesn't. You can't disconnect the drive mechanism from the wheels in a Prius. Neutral in a Prius just disables the power electronics that drive the motor-generators.
    priuscatprimeguy likes this.
  17. Sam Spade
    2,036
    1,023
    2017 Prius c
    OK a slight mis-wording maybe.
    An electrical disconnect is still a disconnect.
  18. priuscatprimeguy
    2,730
    2,640
    ok, who's the wise guy that pulled the plug on my Prime?:mad::p
  19. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Shifting to neutral does a lot of things that, if you use neutral, you should be aware of. There are many older threads on the pros and cons. If you feel the need to use neutral, you should look them up. It is a lot more than unhooking the engine from the wheels.
  20. Mendel Leisk
    38,735
    I basically like Neutral for parallel parking on a hill: to roll a tire into contact with the kurb, with just gravity, sans engine motivation.
