Regenerative Braking - What's the "best" way to brake?
Discussion in 'Gen 2 Prius Technical Discussion' started by nerka, Nov 4, 2008.
  1. nerka
    nerka New Member
    Cleveland, OH
    I am a PROUD owner of a 2009 Prius. I think it's a Package 6, but I don't really know the numbers (it's loaded NAV and leather.) Anyway, that doesn't matter.
    I'm wondering if there is a "best" way to break with regenerative breaking. Is it better to break over a long distance...slow, steady breaking or is firm/harder pressure over a shorter distance better? (Or doesn't it matter?)
    LOVE this car and am loving learning how to drive to maximize my MPG. Now if I could only get someone to install one of those overrides for the NAV and Bluetooth operations...what a drag!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    re: Regenerative Braking - What's the "best" way to brake?
    We prefer you don't break your Prius...title edited...
  3. efusco
    19,891
    1,191
    Nixa, MO
    It's best not to brake at all...or as little as possible. So anticipate lights, slow down early, don't follow behind other cars very closely, etc.
    When you do need to brake you should do so with moderate slowly applied pressure. Don't brake suddenly or hard or you'll kick out the regen part and go straight to friction braking.
    Moderate braking optimizes the amount of energy regenerated...that said, it's still best to avoid braking and to slow down only when necessary and over the longest possible distance to optimize FE and energy use.
  4. nerka
    nerka New Member
    Cleveland, OH
    Thanks. In general I do try not to break... even after only a week of ownership I realized that makes the most sense. I suppose given that, what you suggest should have been intuitively obvious!
  5. Silver 2008
    Silver 2008 Junior Member
    71
    Idaho
    Batteries can accept more of the energy at a slower rate. They receive optimum benefit from the braking if it is over a longer distance. More heat is generated when the charge rate goes up. Heat is energy wasted.
    Mike
  6. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I usually place my foot on the brake pedal, and then press down.
    Generally, I use as much pressure as is necessary to avoid running red lights, running stop signs, or hitting small children/animals.
  7. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    Yes, given its new I would not want to break it either....
  8. efusco
    19,891
    1,191
    Nixa, MO
    Wus...don't come around here calling yourself a hypermiler!:p
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    It's brake, not break. The first hint didn't work, so I'll just point it out directly.
    Tom
  10. Wa1hog
    Wa1hog Old Blind Hippie
    95
    South West New Hampshire
    Before I got my 08 I could'nt understand why everyone was gettinhg 100k between brake pad replacement.
    Now I know why.
    You coast most of the time when your slowing down.
  11. nerka
    nerka New Member
    Cleveland, OH
    Geez...harsh crowd. Yes, I know it is "brake" and not "break." That's why it is correct in the title. So I screwed up after that...
  12. efusco
    19,891
    1,191
    Nixa, MO
    Well....you screwed up the title too...I took mercy and edited it for you.
  13. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Hi nerka
    Welcome to the site and Prius ownership. It is a great car and a great site.
  14. Joe C.
    Joe C. New Member
    Milford, MA
    Mike
    2008 Package 3 - Silver. OEM Mudguards, OEM All Weather Mats, WeatherTech Cargo Mat, NuShield MFD Protector, Tint, Nokian WR-G2s, Trim Ring Delete, and Killed the Reverse Beep
    How did you "kill" that annoying reverse beep? It's a dumb idea if you ask me (but you didn't)!
  15. bestmapman
    1,289
    242
    This should help you.
    Link
  16. nerka
    nerka New Member
    Cleveland, OH
    Thanks...seriously. It was my stupid error and I take ownership of that.
    I will strive to a new level of perfection -- one which is clearly required to avoid ridicule.
  17. efusco
    19,891
    1,191
    Nixa, MO
    I don't think anyone's ridiculing you...it's a common mistake, but b/c it's so common it's a bit frustrating for us. Don't take it personally. We're really a friendly welcoming site. Nobody expects perfection, but a gentle reminder on a key spelling or gramatical point now will make your life easier next time your brakes break!:D
  18. qbee42
    18,058
    3,073
    Northern Michigan
    So, Evan, are you saying that we should give him a brake? Whoops, I mean break?
    Tom
  19. qbee42
    18,058
    3,073
    Northern Michigan
    Nerka, Evan made a gentle suggestion that you had used the wrong "brake", but you didn't seem to take notice. That's why the next comment was less subtle.
    Tom
  20. Silver 2008
    71
    Idaho
    It look like bestmapman took care of you with that link. It is... er... was very annoying.
    Mike
