regenerative braking
Discussion in 'Gen 2 Prius Main Forum' started by earthman, Jul 24, 2009.
  1. earthman
    earthman New Member
    47
    Vermont
    does light braking down a hill charge batteries quicker than just coasting down?
  2. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Yes. It's not more efficient though.
  3. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Yeah, the most efficient method would be to actually accelerate slightly as you go down the hill (assuming that you decelerated going up the hill by using little gas, so that at the top you're somewhat under the speed limit). ;)
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i think people on here calculated it's 10% to 15% more efficient to use the regenerative function through braking, instead of just coasting. the gen III is probably a lot more efficient.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Coasting is generally more efficient, unless your speed gets excessive. With coasting all of the potential energy is converted into kinetic energy. With regenerative braking you lose a lot through conversion from mechanical to electrical to chemical and back.
    Tom
  6. earthman
    earthman New Member
    47
    Vermont
    Wow! Ask what you think is a simple question and come away scratching your head......huh?? OK, I do suffer from TBI, the result of a motorcycle accident several years back. It still is more difficult to think things through. So maybe I'll just blame it on that. Although my daughter tells me that excuse is getting old.
    Here is what has me wondering. I leave my house, go a short distance then have a two mile hill to roll down with a stop at the bottom. My SOC is usually somewhere near the bottom but still in the blue bars at the top of the hill and back in the green, near the top or peaked out at the bottom of the hill. I'm wondering if I get there quicker (peaked out , in green) just rolling down the hill (in gear) or if I get there quicker by lightly applying the brakes while rolling down the hill.
  7. JimboK
    2,817
    187
    49
    Chesterfield, VA
    Again, you'll get there more quickly by regenerative braking.
    Are you trying for green bars? There's really no need for that or any value to be served. As we've stated, it's less efficient to use the brakes than it is to just let momentum go directly to work for you moving the car. My goal is to avoid the brakes or, for that matter, any regeneration at all, as the lack of regeneration icons on this from my morning commute shows:
    But then I'm a little more obsessive with fuel economy than most. ;)
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    You will charge more using regenerative braking. When coasting with no brake or throttle regeneration is at its' minimum (but non-zero).
    What the above posters are trying to say, in an unclear manner, is if you regenerate power then use it later it's only -about- 50% efficient due to losses in the cycle of generation, storage, recovery, and reuse in the motor.
    If you use that power (gravitational energy in this case) to push the car, then you get to use almost all the energy.
    In your case, if you have to stop at the bottom of the hill, it's probably better to lightly brake all the way down.
  9. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Yep, the key here is that you SHOULDN'T be trying for green bars. It's most efficient to let the system decide when to charge the battery, and to brake as little as possible (in other words, brake only when necessary). ;)
  10. rcf@eventide.com
    173
    85
    Sedona
    Ask a simple question and you get a pageant!
    It's generally true that arriving at the bottom of the hill with maximum kinetic energy (faster) is better than charging the battery and getting there at a slower speed.
    BUT
    If the hill is long enough, and at two miles it may well be, you will probably reach an "equilibrium" speed before you get to the bottom. At that point, you are balancing the loss of potential energy with internal friction, aerodynamic braking, and battery charging. If you can brake for the upper part of the hill and then coast long enough to still reach the bottom going at the equilibrium speed, you're better off doing so. That way you will have more energy in the battery and still get to the bottom with the same kinetic energy.
    Of course, if there's an unpredictable traffic light on the hill or at the bottom, it's a lot more tricky unless you can also time the light(s) using your GPS or other methods.
    Richard
  11. earthman
    earthman New Member
    47
    Vermont
    Thanks to all for the explanations.
    Jimbok, I thought it would be more efficient for regenerative braking to charge the battery than the ice........wrong again?
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Earthman, are your asking this question as a quest for understanding, or are you satisfied with whatever gets you more MPG ?
    If's it the latter, consider this: Fuel was not needed to get to the bottom of the hill and to recharge the battery along the way, so why spend it?
  13. JimboK
    2,817
    187
    49
    Chesterfield, VA
    Assuming a depleted charge, yes I let the ICE recharge it as much as possible, but not through ICE-on coasting, if that's what you're asking. In fact, I avoid coasting, defined as foot off the pedals, altogether when possible. Instead, I glide when I can: feather the go-pedal just enough so that all arrows disappear on the Energy monitor. Do a good search of "pulse and glide" for more.
    Best is to avoid the need to recharge. In other words, avoid using the battery. Instead, either let the ICE go to work directly moving the car or let available kinetic energy continue to move the car as much as possible with minimal impact on the battery by gliding.
    I'm not sure whether you're asking 1) What's the most efficient way to decelerate? or 2) What's the most efficient way to charge the battery?
    Assuming #1, here are the various methods of deceleration in descending order of efficiency:
    1. No-arrows gliding
    2. Pedal-free ICE-off coasting
    3. Light (regenerative) braking
    4. Hard (mechanical) braking
    5. Hitting a large stationary object :D
    Frankly, I'm not sure where ICE-on coasting would fall in this list, possibly somewhere between 3 & 4.
    Assuming #2, I largely let the ICE charge it when the ICE is propelling the car, with whatever regeneration happens to come my way. Though I try to avoid regeneration, total avoidance is impossible and some regenerative recharging is inevitable.
  14. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    If you're going down hill to a stop, yes, you'll capture more energy by using the brake.
    If you're going down a slope while cruising, it's more efficient overall to let it coast.
    It's all about using momentum. In the first situation, your momentum is energy you should capture. In the second, it's energy you should directly use to continue driving the vehicle forward. If you were to brake and slow the vehicle, you may have to expend energy to regain velocity lost.
