Regenerative power "cars" conversion to battery "bars"
Discussion in 'Gen 3 Prius Technical Discussion' started by Bigchuckles44, Feb 4, 2010.
  1. Bigchuckles44
    Bigchuckles44 New Member
    Boise, ID
    Is there any conversion between the little "car" symbols you see in the 1 minute and 5 minute fuel monitor to the number of bars you see in your battery?
    It would be simple if you could say one "car" equals one "bar", but I doubt it, since it is a different amount of power shown for a "car" when you are on 5 minute or 1 minute monitoring.
    Any ideas?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    It's not a simple conversion. Each car is a fixed amount of energy, but the battery bars are not. The battery bars have a non-linear relationship to charge, with the center bars representing more stored energy. Likewise there is some loss recharging the battery.
    You could map it out on a bar by bar basis, but it wouldn't be worth the effort. It's probably better to use some crude rule of thumb.
    Tom
  3. bwilson4web
    15,401
    Add to that it doesn't show 'negative' car symbols. When the car needs traction battery power, it just takes it without showing it in "car symbol" units. It also adds traction battery power as needed, again without showing it in "car symbol" units.
    If you really want to do the mapping of "car symbol" to battery bars, there is a way but it is crude and ugly:
    • at the top of a large hill or mountain, use EV mode on a flat road to run the battery as low as possible
    • creep to a road that smoothly descends the mountain
    • start the video recorder and wait for display to update
    • let the car descend the mountain while the video camera runs
    • at the bottom, pull over to the curb and wait for the display to update
    • turn off the camera
    This should give you "m" cars and "n" bars. With the change in altitude, we can calculate the change in potential energy, the maximum that could have been stored. Like I said, it is not an easy thing to do.
    Is there some thing you'd like to use such data for?
  4. Bigchuckles44
    Boise, ID
    No, but thanks for the inputs. Just curiousity. I see the car symbols show up in the weirdest situations and times.
    I do love my 2010 Prius. Have had no problems at all with it. I have had it 5 weeks now, just barely over 1000 miles. Best mileage has been about 48 mpg, but I do notice it is getting better, so breaking in is definitely helping it.
    Bottom line is, I love it and everything about it.
  5. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    You should only see them when you use the brakes.
    Braking will always be bad for fuel economy. On a Prius, it simply is less worse than on other cars. Only brake when you absolutely need to and when you do have to use them, try to use a slow deceleration to maximize use of the regenerative system.
