Regular battery vs interior hybrid battery
Discussion in 'Gen 3 Prius Main Forum' started by choloperuano, Dec 17, 2018.
  1. choloperuano
    choloperuano Junior Member
    Coeur d Alene, Idaho
    What is the difference between a regular joe battery, say $70 or so, vs a $200 or more battery? I haven’t been able to find much and get a good enough answer out of the dealership. Not that I would trust them anyway.
    Thanks in advance!
  2. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    A Brand(y)
  3. EyePrime
    268
    115
    2018 Prius Prime
    No but seriously its proboably more reliable and a better warranty
    52,382
    just so no one gets confused, you show a 2010, but posted in the prime forum.
    for the 2010, the battery is in the hatch, so there is a safety concern regarding the air you're breathing
    there are alternatives to the oems battery, maybe as cheap as $150.
    you want gel, you want a vent tube, and you want the correct size and post orientation. prius battery is a very odd size.
    warranty is also a consideration.
    Robert Holt, Sporin, Pluggo and 2 others like this.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Firstly, electrically, nothing, both will power your car.
    Secondly, if you really have a Prime and not the 2010 listed in your Profile, still not much. If it fits in the mount under the hood, and has the right posts, you are fine.
    Third, if you still have the 2010, then you have new issues. Your battery is in the passenger compartment with humans, not outside in free air. Your battery will generate Hydrogen under certain circumstances, from 4% to 75% Hydrogen in air, it is combustible. You will never get 4% of the outside to be Hydrogen, but 4% of the passenger compartment is a real possibility. In addition, the battery contains Sulfuric Acid, and whether via an accident or chemical reaction, you want the very least Sulfuric Acid splashing around the interior of your car. Finally, Toyota has used a rare JIS post while over 90% of car batteries use a SAE post.
    So you want an externally vented AGM battery of the S46B24R size with JIS posts.
    www.amazon.com/dp/B010GKJ8F6
    Meets the specs for $145.25, which is somewhat better than $200.
    Locally, your NAPA Auto Parts store may have one for $186
    https://www.napaonline.com/en/p/NBP9851P
  6. bisco
    52,382
    jumbo, why did you repeat everything i stated in post #4?
    priuscatprimeguy and Raytheeagle like this.
  7. Mendel Leisk
    41,894
    Wait for OP to get back and clarify?
    Raytheeagle likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Emphasis;).
    But I’m sure he appreciates the kind name you refer to him as(y).
    priuscatprimeguy, kc5dlo and bisco like this.
  9. choloperuano
    Thank you for the info and the link! Sorry if I posted in the Prime section, I hadn’t realized I did. I’ll pay more attention to that in the future :)
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    So......the real answer is:
    Convenience......and volume.
    The Prius battery is a little different than most, both in size and post connections.
    "The factory" doesn't make a lot of them so the price is higher.
    IF....you are resourceful enough, quite a few different, less expensive, batteries can be made to work.
    If not, you pay the asking price and don't worry about it.
    I think Pep Boys is a common source for ones that are a bit less expensive and are "exact fit".
  11. bisco
    52,382
    spell check, like biscottis :oops:
  12. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Biscottis a fantastic holiday treat:).
    Some spell check isn’t bad I guess(y).
    priuscatprimeguy and bisco like this.
  13. bisco
    52,382
    it used to change to disco, danny must've updated spellcheck
  14. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    The warranty should give a clue on if the manufacturer is confident in the quality of their product. Is the warranty twice as good for the $200 battery? For a while I ran with the yellowtop batteries because they will tolerate a deep discharge with little harm. The stock battery not so much. The battery is so small it doesn't take much to discharge it.
    They may neither know nor care. They sell the dealer battery for the dealer price, period. If you have the battery that lives in the back right corner, inside the cabin with you, then you need the little vent tube. For what it's worth, I had one car where I swapped out those little midget terminals so I could use a more normal battery in the future.
