Reminder: Check spare tire pressure
Discussion in 'Gen 3 Prius Main Forum' started by drinksta, Sep 12, 2017.
  1. drinksta
    drinksta New Member
    Utah, USA
    I had a flat tire today on the interstate highway. Luckily I saw the TPMS light was on because I could not really feel the rear tire was flat (I have low profile tires from Prius 5). Luckily I had checked the pressure of my spare tire a couple weeks ago (it was only 15psi). It should be 60 psi. No need to get stranded because your spare tire is flat too.
    uber2016 likes this.
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Good tip! Thanks! I check mine every couple of months, and last time it was still at 60psi! :)
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Sigh, I guess I had better check mine too. Too bad the "engineers" at Toyota can't figure out the spare should be stored with the valve -up- so we don't have to remove it to check it. Or maybe they want us to visually check under the spare for whatever may be hiding there.
    I guess I should just be thankful I -have- a real spare. ;)
    BruceInOKC likes this.
  4. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Or better, install TPMS to alert when low. Show which tire is low in TPMS too.
  5. Mendel Leisk
    38,702
    Just a Public Service Announcement: check the pressure (and condition) of that spare!
    Take a look in all the corners too, check for water, bugs, dirt, vacuum and/or blow it all out.
    Johnny Cakes and WilDavis like this.
  6. Johnny Cakes
    Johnny Cakes Senior Member
    1,015
    764
    Virginia, USA
    Any photos on the Internet showing the how everything is supposed to go back together under the floor? Somehow I ended up with a rubber do-hickey left over. Googled but didn't find.
    Also, anyone using something other than the OEM "tool" to crank up the scissor jack? It works, but sheesh!
  7. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    You use it to hang a beer on the hook as your changing tires and reward yourself with the beer afterwards.
  8. Prodigyplace
    11,696
    11,318
    Central Virginia
    My spare doesn't have corners. Does that mean it needs to be replaced? Mine appears round.o_O
    ASRDogman and Mendel Leisk like this.
  9. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Mendel has the Canadian prius edition with square wheelntires, snow and ice are no match with his prius.
    RMB and Prodigyplace like this.
  10. Mendel Leisk
    38,702
    The connection for the the "shepherd's crook" is the issue I think. It's a single, cast eye, soft metal that spalls with each rotation:
    (Stock image, similar)
    This is the Honda style, much more stable:
    A heavy rubber band with a hook on the end? That's a hold-down for the jack, in the plastic cradle.
    Prodigyplace likes this.
