Featured Reminder for drivers in the Northern Hemisphere
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Leadfoot J. McCoalroller, Nov 7, 2025 at 12:45 PM.
  1. Leadfoot J. McCoalroller
    8,052
    7,533
    Pennsylvania
    2018 Prius c
    Temperatures are dropping!
    This weekend is a good time to check your tire pressure and top it up.
    With lower temps you may be a few pounds low- maybe not enough to trip the TPMS (if any) but you can still lose fuel economy before that tire light comes on.
  2. PriusCamper
    PriusCamper Senior Member
    12,619
    5,099
    Pacific Northwest, USA
    I'll also suggest basing your tire pressure needs on the roads you drive on rather then what the tire maker's lawyers decide to stamp on all the tires. As in add a couple few pounds of air at a time and then on a rainy day if your tires slip a little accelerating hard away from a stoplight you know to lower tire pressure a little to improve traction. And as always, because the engine is in the front you'll want a couple pounds more in the front than in the rear. In winter for me that works out to about 45psi in front and 43psi in the rears and higher than that in the Summer.
