Remote A/C question from a woman
Discussion in 'Newbie Forum' started by Trina G, Jul 23, 2013.
  1. Trina G
    Trina G New Member
    Colorado
    My husband told me to "read my manual" when I asked him this one. He said it like he knew the answer but wants me to be well informed. I am against this on principle. I cook, therefore car answers should be delivered to me in a dumbed down version. So if anyone could please dumb this down for me I'd appreciate it...
    Does the remote A/C work the same in cold weather as it does in hot weather? It's pretty hot this summer, so I have the temperature set to a comfortable cool temp and the car is considerably cooler when I enter. So, in the winter, if I have the temperature set at a warm temp, will it heat for me while I am clearing snow off the windows? I do not have the remote start option, and am wondering if I will even need it. And if it does work this way, will it pick up defrost if I leave the car set to defrost before exiting?
    Please don't make me read the manual... I read through page 79 and then went to clean the toilets for fun.
    jgilliam1955 likes this.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    My understanding is it will run at the last temperature setting you shut the car off with. If your in close proximity and hit the a/c button and the battery has enough juice it will rUn for 3 minutes.
    Let someone confirm
  3. Nora
    Nora Member
    128
    44
    CO
    Just ask your question. Try not to insult the rest of us.
  4. exbauer
    exbauer Active Member
    1,185
    99
    Washington
    It will not work the other way around. It will not heat your car, only cool it. Try and turn it up to 80 and use the remote AC. It will not work.
    JMD likes this.
  5. Trina G
    Trina G New Member
    Colorado
    I was teasing, Nora. Anyone knowing the answer is smarter than me in this. I would never insult them. I'm quite happy to have found this forum. Most people seen pretty happy and upbeat. I'll not make that mistake again.
    domer1970 and Merkey like this.
  6. domer1970
    domer1970 Junior Member
    2013 Prius Plug-in
    Nora, I read the post and wasn't insulted in the least.
    Your use of the phrase "the rest of us" segregates forum newcomers from who? Time-pressed techies? Humorless tree huggers?
  7. JMD
    3,779
    1,282
    Remote AC is one thing, but there is a remote start option which can start the car when you are outside the car. It is about $600.
  8. Nora
    Nora Member
    128
    44
    CO
    Sorry, Trina. I guess I was feeling crabby. Welcome to the forum, and I hope you enjoy your car!
    Nora
    Humorless Treehugger
    Trina G likes this.
  9. parnami
    parnami Member
    227
    47
    .Lancaster, PA (Amish Country) :)
    Your AC is electric, so it can operate on battery power alone, which is what happens when you turn it on, remotely. When the bat runs low, the ac stops. It never turns on the engine.
    Heat, on the other hand, requires the engine. There is no electric heat in the Prius. The remote ac button will not work to provide heat.
    DZD and Trina G like this.
  10. jgilliam1955
    368
    102
    Williamsburg, Virginia
    Drive to northern canada and try it. Then let us know.:p Seems like no ones for sure. I have the remote and seems to me if the auto temp button is set it will either cool or warm the car. I havent had my car long enough to know.
  11. qdllc
    qdllc Senior Member
    1,370
    399
    When I made the choice of what level Prius to buy, the automatic A/C option seemed nice, but once I learned that HEAT needs the motor, the remote starter for $800 (what I was charged) was a better deal than $1,500 or more for a trim level that gave me the lesser feature.
    JMD likes this.
  12. JMD
    3,779
    1,282
    Smart move :)
