Remote AC on key fob
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ronlprius2, May 21, 2012.
  1. ronlprius2
    ronlprius2 Junior Member
    56
    San Francisco
    Neither my dealer nor I can get the remote AC to function on my PiP. Has anyone gotten it to work and how did you do it?
    Thanks!
  2. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Yep, I use it quite a bit.
    Hold down the AC for 2 seconds. Car will lock all doors and turn on the AC to the past set temp. Will run for up to 10 mins. Turns off when you open the door.
    Double click the button to turn it off from the key fob.
  3. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
  4. flim
    flim Active Member
    241
    166
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    You can also use Entune Remote Climate on your Smart Phone if you have the Advanced PIP
  5. CharlesH
    2,796
    1,162
    Roseville, CA
    ... Where "smartphone" = iPhone or Android
  6. ronlprius2
    56
    San Francisco
    Outside temperature? My AC is set to 68, outside temp is 70 but inside the car it's around 90 because of the sun. Should the AC still work? PS: I have the "cheap" model.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Yes.
  8. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Here's the related information from the Owners Manual (p371)
    !Operating conditions
    The system will only operate if all of the following conditions are met:
    "The shift position is in P.
    "The “POWER†switch is OFF.
    "All doors are closed.
    "The hood is closed.
    "The brake pedal is not being depressed.
    !When leaving the vehicle
    "Check that the headlights are switched to either off or “AUTOâ€.
    "Check that the wiper switch is turned off.
    "Check that all windows are closed.
    !Remote Air Conditioning System automatic shut-off
    The system will automatically shut off under the following conditions:
    "About 10 minutes have passed since operation began
    "Any one of the operating conditions is not met
    "There is only a slight difference between the air conditioning set temperature
    and the inside temperature.
    The system may also shut off if the charge level of the hybrid battery (traction
    battery) drops to low. (P. 52)
    !Conditions affecting operation
    The system may not start in the following situations:
    "The charge level of the hybrid battery (traction battery) is low (P. 52)
    "The air conditioning temperature is set at a high level or outside temperature
    is low
    "When the hybrid system is cool (for example, after being left for a long
    time in low temperatures)
    Security feature
    Any unlocked doors will be automatically locked when the system is operating.
    The buzzer will beep and the emergency flashers flash when the doors
    have been locked or the system has been turned off.
    (The doors locked: Once; The system turned off: Twice)
    P. 119
    !When using the Remote Air Conditioning System
    A charging message will be displayed on the multi-information display. Different
    messages will be displayed depending on when the Remote Air Conditioning
    System was started (after charging or during charging).
    (P. 562)
    !While the Remote Air Conditioning System is operating
    "Depending on the operating condition of the Remote Air Conditioning
    System, the electric fan may spin and an operating noise may be heard.
    However, this does not indicate a malfunction.
    "The Remote Air Conditioning System may stop operating temporarily if
    other features that use electricity (for example, the seat heater, lights,
    windshield wipers) are in operation or if the charge level of the 12-volt
    battery becomes low.
    !Electronic key battery depletion
    P. 123
    !When the electronic key battery is fully depleted
    P. 123
    !Customization
    Setting (e.g. Operation using the on the wireless remote control) can
    be changed.
    (Customizable features P. 645)
    Precautions for the Remote Air Conditioning System
    "Do not use the system if people are in the vehicle.
    • Even when the system is in use, the internal temperature may still
    reach a high level due to features such as the automatic shut-off. Children
    and pets left inside the vehicle may suffer heatstroke or dehydration,
    or could result in death or serious injury.
    • The wipers can be operated during system operation. Children or pets
    left inside the vehicle may mistakenly operate these and cause an accident.
    "Depending on the surrounding environment, signals from the wireless
    switch may transmit further than expected. Pay appropriate attention to
    the vehicle’s surroundings and use the switch only when necessary.
    "Turn the wipers off. If the Remote Air Conditioning System operates while
    the wiper switch is in the on position, the wipers may operate and objects
    may get caught in the wiper blades.
    "Do not operate the if the hood is open. The air conditioning may
    operate unintentionally and objects may be drawn into the electrical cooling
    fan.
    NOTICE
    !To prevent the hybrid battery (traction battery) from being discharged
    through incorrect operation
    Use the only when necessary.
  9. janie
    janie 2016 Prius 3 Touring
    175
    42
    Three Touring
    A week or two ago, I experimented with my base package Plug In Prius, while I was sitting in the car, and it was being charged at a charge point station inside a covered parking garage.
    I clicked on the a/c button, and it did turn on :) the doors were closed and locked, the lights were in off position, and my foot was not on the brake at the time.
  10. flim
    flim Active Member
    241
    166
    2023 Prius Prime
    XSE Premium
    I am using the iPhone and Android has the Toyota Entune App too!
    I also like the Vehicle Finder, it's like the "Find My iPhone".
  11. CharlesH
    2,796
    1,162
    Roseville, CA
    Isn't that what I said :confused: ? And yes, I understand that at this time these two total to about 95% of the smartphone market. But nonetheless, the Bluetooth Blackberry Phone Contacts/SMS/E-Mail integration works very well on the Plug-in.
  12. flim
    flim Active Member
    241
    166
    2023 Prius Prime
    XSE Premium
    Ron,
    I wonder if this was similar to a previous issue with my 2010 Prius. It came with remote engine start, I followed the simple instructions to start the engine which it did and it shuts off after a few seconds.
    Took the car to the dealer and nobody can get it to work. The dealer wanted me to leave the car for a few days to troubleshoot.
    I finally brought it up to the dealer's service manager and they contacted Toyota to get some feedback. They finally found out my software wasn't installed properly or there was a missing step.
    After reinstalling the software, the remote engine start was operational
  13. pip2012
    pip2012 Junior Member
    San Jose
    I have been able to get the A/C to pre-cool as long as all the previously stated restrictions are true.
    But what about pre-heating while connected to a charger. It's unclear reading the manual if that's supposed to work or not. Based upon the descriptions given it seems unlikely that it would preheat the car - even if you set the temperature to higher than the outside air temperature (and higher than the inside air temperature) and set the controls to heat or defrost.
    Should this work?
  14. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    No.
    Main reason being the PiP needs the engine for heat. Second reason is the Remote A/C will not work if the outside temp is lower than what you have it set to.
  15. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    As stated, no, no pre heating.
  16. ronlprius2
    56
    San Francisco
    Are there 2 different traction batteries in the PiP? One that the charger charges and one that the engine charges? The battery image shows full but the miles remaining is blank because I've used it all up. This is when the remote AC doesn't work.
  17. janie
    175
    42
    Three Touring
    I noticed that once my EV range is to 0, I do get a new full battery that shows up- but that is not the EV battery. And you are correct, the remote AC will not work once your EV range is to 0, you would need to recharge your battery (or at least have some EV range) to be able to use the remote AC :) that is my understanding of it . . .
  18. iRun26.2
    iRun26.2 Active Member
    767
    151
    United States
    There's one traction battery that the system uses for both EV and HV modes. The way the car displays the battery data, it appears that there might be two traction batteries, but really, there is just one.
    It is a matter of software (which we can not not directly control). You are not allowed to use the small bit of EV charge of the HV section of the battery until the engine goes through a warm up cycle.
  19. Barbara R
    Barbara R Junior Member
    44
    2014 Prius Plug-in
    We just got our 2014 Prius. My question on Remote AC is, is there any way to tell if it worked? I mean, if I'm not close enough to hear the car beep? It looks like the red light blinks on the fob whether it got activated or not. Thanks!
  20. bisco
    51,140
    welcome to priuschat! i'm not sure, perhaps the lights flash as well?
