Remote Battery getting exhausted
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by itengineer, Apr 7, 2015.
  1. itengineer
    itengineer Member
    85
    25
    Minneapolis
    Hi All,
    The battery in my remote appears to be getting exhausted quickly.
    The fist time it happened was in 2014 when batteries on both remotes got spent. (for a 2011, I figured that it was normal).
    I picked up a 8 pack from Amazon and replaced batteries on both remotes but the frequency of exhaustion has increased dramatically.
    In fact, the last battery on my main remote only lasted 2 weeks.
    I have only been using the batteries from the pack I got from Amazon and it is entirely possible that I got a bad pack but are there any other theories out there ?
  2. JC91006
    16,673
    8,518
    buy different batteries and see if it changes. fob batteries don't drain that quickly
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    But when you get 8 from Amazon for $4......those often do. :(
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    I have a customer with a fob that just began having a similar battery drain issue. Batteries lasting 2 weeks or less. Has gone through two of them so far. Got them both from the local hardware store which is reputable.
    Tried their secondary fob, and that one does not seem to have the battery drain issue.
    Checked all the buttons and they seem to be operating (clicking) just fine. LED light comes on only when a button is pressed.
    Now is trying to determine if it is the fob itself, or just some sort of issue between the fob and the Prius.
    Is currently trying this:
    Put new battery in the fob.
    Put the fob at the far end of the house (after confirming that the fob cannot communicate with the car)
    Wait two weeks.
    See if fob battery has drained at all.
    Please keep us updated with your experience/resolution.
    gdanner likes this.
  5. Easy Rider 2
    1,584
    258
    Ocala, FL
    Places like that don't typically sell a lot of those kinds of batteries.
    Batteries have a shelf life.......no matter how reputable the store is.
    Were the new batteries tested at all before installing ??
    kenoarto likes this.
  6. bisco
    51,154
    test them. someone else said amazon batteries were only 3 volts.
  7. itengineer
    itengineer Member
    85
    25
    Minneapolis
    They're supposed to be 3V. My Amzn battery read 3.3V but it still failed after 2 weeks. I just put a different one in bought at a local store.
    We'll see how this one performs.
  8. FrankB
    FrankB Member
    117
    53
    FWIW, make sure the foam in the FOB is in the correct place over the battery as I had trouble with going through batteries quickly (more than two weeks but less than a year) when the foam was out of place.
  9. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    Batteries were tested ahead of time.
  10. Jim T
    Jim T Junior Member
    22
    New York State
    One of my key fobs developed the same problem. I kept the fobs at the far end of the house from the garage and away from electronics but it still depleted the battery in just weeks. I burned through one or two Energizer CR1632's from a 100% rated high volume Amazon seller, but still wondered was it bad batteries? Took it to the dealer and they required putting their own battery in so I had to come back a couple weeks later for them to verify the voltage was low. The key fob was replaced under warranty as I was still within a year on my certified used purchase.
    My remaining original fob lasted 6 months of active use on a new battery before getting a low battery message on the car display. I'm now at 7 months use on my replacement fob on a battery that was replaced 14 months ago.
  11. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    But the shelf life of those batteries is several years without drastic deterioration.
  12. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    It's good (I guess?) to confirm that others have experienced mysteriously draining fobs.
    Would be nice to get to the bottom of exactly how/why they are draining. Seems a waste to get rid of it if the problem could be easily fixed.
  13. Jim T
    Jim T Junior Member
    22
    New York State
    My service notes on the warranty replacement just stated "internal short"
  14. bisco
    51,154
    it's difficult with limited communication from the o/p.
    #14 bisco, Apr 9, 2015
  15. Siward
    Siward Active Member
    312
    126
    Toronto
    Are you leaving your keyfob near your car? I once had a Prius brochure that told me never to leave my keys within 2-3 meters of the car as it drains the battery due to the smartkey system.
  16. bisco
    51,154
    why would that be a problem?
  17. itengineer
    itengineer Member
    85
    25
    Minneapolis
    UPDATE:
    So, the fresh battery (purchased from a quality local store) that i put in on Tuesday was all spent today(Friday)
    I measured the voltage on Tuesday and again on Friday
    Tuesday: 3.3V
    Friday 2.58V
    The remote would not function with the 2.58V battery. I think I can rule out the quality of the batteries as a factor.
    Also, since this is happening to both FOBs, i am going to rule out an internal short as a cause.
    I am leaning towards RF interference from the phone and/or WiFI. I know that the iPhone and the keys sit in the same pouch of wife's handbag sometimes touching each other. I also recently moved the WIFI router to my main living room from upstairs.
    I have turned off bluetooth on the iPhone. I will also try to get a RF shielding pouch to store the keys in.
    More to follow.
  18. bisco
    51,154
    do you live near a defense installation?
  19. itengineer
    itengineer Member
    85
    25
    Minneapolis
    No, live in Suburbia.
    it could be the communication with the Prius - not sure what it does exactly
  20. bisco
    51,154
    the car continually seeks the fob 24/7. when the fob is in range, they communicate with each other. normally, the battery lasts 3-5 years, depending on how much you drive. if you keep it at the other end of the house, there is something else that is causing it to activate. as the manual states, cell phones, cordless phones, other fobs, what have you. if not, then something in your circuit board has gone bad.
    gdanner likes this.
