Remote Climate - Entune App
Discussion in 'Prime Audio, Electronics, and Infotainment' started by RMORRIS653, Mar 1, 2017.
  1. RMORRIS653
    RMORRIS653 Junior Member
    NEW YORK
    Any update to the Entune App ? Has anyone had it work consistently on the Advanced model - i am being told by my dealer that a fix is still not in place. Very frustrating
    thanks
    rich
  2. koryliss
    koryliss Junior Member
    Zion Crossroads, VA
    It almost always turns on the climate control in the car but I sometimes do not get a confirmation on the phone. I get to the car and the heat is on but the phone is still spinning as if it is still sending the instruction to turn on the climate.
    xtins likes this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I found that to be true on my Android Phone so I click on the back button which clears the spinning and shows the actual climate working with the time remaining.
    Nic Steussy and xtins like this.
  4. xtins
    xtins New Member
    26
    US
    Yeah, me too. Exactly like the and sometimes comes right but it's working good.
  5. RMORRIS653
    NEW YORK
    thanks -- i will check with the dealer --- none of the added entune features work with my car
  6. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,303
    3,519
    Anaheim, CA
    Hi Rmorris,
    Just searched Entune on PriusChat to find your older post here. I have a Prime Advanced which has developed an Entune problem: the inability to respond to my requests to check charge status or operate Remote Climate. The automatic reporting of the charge status still works, but the system doesn't respond to my manual request for charge status or Remote Climate.
    Toyota Corporate Tech Support are "working on this". I wonder how many of you Advanced owners have had this problem. It worked at one time and I uninstalled/reinstalled the App several times to try to get it to work. I'm now at Level 2 support with Toyota Corporate.
    HEY!!!! I just checked the Entune App for my charge status and it works GREAT!!
    The folks at Entune must've fixed it!
    Thanks guys/gals !!
    #6 HPrimeAdvanced, Apr 26, 2017
    Nic Steussy likes this.
  7. bodgm
    bodgm Junior Member
    58
    US
    Same story here. Mine hadn't worked and after reading your message, I checked my Entunes ap and it worked. Thanks!
  8. RMORRIS653
    NEW YORK
    unfortunately my app is still not working
  9. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
    Mr. Morris, I suggest you do what I did contact Toyota Corporate, and indicate to them that Entune is not functioning properly with a detailed description of your problem. It took them two days but they finally fixed mine. It works great now. I used to have to wait about 2 minutes for the car to respond; it now takes about 20 seconds. Both features work, but remember, you must leave your car locked for Entune to be able to trigger the Remote Climate app.
  10. CoolMoon
    CoolMoon New Member
    I had the same problem after it worked for a couple of weeks. Which number did you call for support? And do you know what they did on their side? Thanks!
  11. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
    I believe I called (800) 331-4331, which is Toyota Corporate Customer Relations number. You then have to select the appropriate extension for the Entune application. The woman who helped me, Devey, did not know what the technicians did, and I never did find out how they fixed it. It's still working; I check it 2 or 3 times each day. Good luck, my friend !
  12. CoolMoon
    CoolMoon New Member
    Called the same number earlier this week but had no luck. I was told to find a local dealer to take a look at this issue. What did you ask for?
  13. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
    I selected the Entune app extension from the choices given. It took several steps, and I finally reached the person who was basically a customer relations person. I told her my problem, and she said that she would have the technical support people take care of it for me; it took at least two days. Ask for Devey if you're getting the runaround. Remember, I'm on the West Coast and I believe her office closes at 5:00pm, PST. I believe she's in Torrance, California, at the current Main Headquarters.
  14. RMORRIS653
    NEW YORK
    i wanted to give you an update -- I am still working this with the dealer and corporate -- -still not working . hopefully soon
    Rich
    HPrimeAdvanced likes this.
  15. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
    I'm sorry it's taken so long; I never even had to get the dealer involved. I wish you good luck and please keep me posted.
    Henri
    Hey CoolMoon, are you on the East Coast like RMorris? RMorris seems to have the same problem you have with Entune and I'm wondering if the problem that you folks are experiencing is related to your location which may be having server access problems. I'm on the West Coast and mine has been fixed. This is obviously just a hypothesis since no one at Toyota has given me an explanation as to how they fixed the problem, whatever it was.
    #15 HPrimeAdvanced, May 17, 2017
  16. Breatheintheair
    45
    78
    Cary, IL
    I was having trouble getting Climate Entune app to work. Then learned that the Prime must be locked before it will work. Now it works just fine.
  17. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
    Sorry, I hadn't been following this post til it "notified" me today!!
    YOU MUST LOCK YOUR CAR FOR ENTUNE REMOTE CLIMATE TO WORK!!
    I should have checked back and added that additional information.
    My bad!!
  18. mr88cet
    mr88cet Senior Member
    2,311
    1,334
    Austin, TX
    Yes, I discovered that as well. The app explicitly pointed that out.
    Then it occurred to me: Shouldn't they have a "remote lock" feature?!
    iPhone ? Pro
    HPrimeAdvanced and Bob Comer like this.
  19. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    You'd thing so, but I think Entune is on it's way out. Looks like Toyota is going for Automotive Grade Linux (AGL) for infotainment starting in 2018 MY.
    Green Car Congress: Automotive Grade Linux platform debuts on the 2018 Toyota Camry
    Unsupervised!
  20. mr88cet
    2,311
    1,334
    Austin, TX
    I've discovered that the process of plugging in sometimes distracts me from locking the car. Plugging in is a break from the habits we've gotten used to in previous cars.
    I need to reinforce the habit of hitting the lock button immediately after I close the driver's door, and postponed thinking about plugging in.
    iPhone ? Pro
