Remote key issues - Passenger locks
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jackmeatball, Aug 19, 2014.
  1. Jackmeatball
    Jackmeatball New Member
    Atlanta
    Hi everyone,
    I have a 2010 Prius and recently the passenger front lock hasn't been locking when I use the remote. I can see the lock trying to close, but then it remains unlocked. I can lock it using the inside lock button on the driver's side door. Am thinking it might be a synching issue with the remote...or someone tried to break into the car and messed up the lock. Anyway, does anyone have any advice? It sucks because I can't use the remote to lock the car and I have to use the door locks on the inside of the car once I put it in park.
    Thanks!
  2. mikefocke
    3,697
    1,645
    Sanford, NC
    You may get more help if the question is not in the Prius v forum. Each model of the Prius has a set of sub-forums.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Even though you are in the wrong forum I will try to answer and let a moderator move this thread to the correct forum.
    Does the passenger door lock work the same with both keys? Have you replaced the battery in your remote ? If it is the original it is a good chance it is the battery.
    49,446
    welcome to priuschat! could be a bad actuator, or even a simple loose connection to the mechanism. either way, you'll have to pull the door panel. all the best!
