Remote Outlet for a Block Heater
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Kremtok, Jul 20, 2016.
  1. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Greetings,
    I'm looking to get a remote outlet that I can control from inside the house to switch on my block heater come winter time. Our garage is detached but not far from the main house. I've looked around on Amazon but the feature that I really want seems to be missing - remote indication that the outlet is on or off.
    Can anyone recommend a solution, please?
    Thanks for your time.
  2. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I solved this problem by getting an extension cord with a power indicator in the end so I can see if it's got power or not. That assumes you have a line-of-sight to the car where the plug is.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  4. fuzzy1
    10,602
    If it is within line-of-sight, I'll vote for some kind of indicator lamp at or near the outlet as being cheaper and more reliable than a remote control. Whether it be an indicator in an extension cord, or a lamp or light fixture or nightlight or even a holiday light string, it is easy and can be selected to consume a negligible amount of power compared to the block heater.
  5. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
  6. Mendel Leisk
    41,893
    Look into timers too. Works for us. I'd suggest 2 hours, maybe 3 in the dead of winter.
