Remote Start....Help!
Discussion in 'Prius v Accessories and Modifications' started by Osteoblast, Feb 27, 2012.
  1. Osteoblast
    Osteoblast Junior Member
    55
    NC
    I just took delivery of the V and was looking forward to the remote start feature it had. The salesman could not figure out how to make it work, and neither can I. I tried the Lock x 2 then hold Lock sequence to no avail. Anyone know the trick?? :confused:
  2. syscon
    syscon Member
    329
    42
    Edm. Alberta
    Why do you need remote starter?
    I'm not sure remote starter on Prius is a good idea, correct me anybody if I'm wrong.
    Prius engine will turn off when coolant temp reaches 40C (104F)
  3. Turdblossom
    Turdblossom Junior Member
    28
    Kentucky
    I don't have a V, but on my four, you need to insure that you are pointing towards the front of the car. The range is rather limited at best a couple of hundred feet. Press the "lock" button on your FOB once, watch your blinkers flash, press "lock" again, watch your blinkers flash again and then hold down the "lock" button until the blinkers start flashing. I had to practice a bit before it came natural to me. Once you get the hang of it, you can practice to see how far away you can be for it to work.
    syscon- the dealer/port installed remote start comes in very handy for defrosting the windows before you drive off. The defroster (both front and rear) will turn on if the temperature is below 40. It will also run the air conditioner (if you leave it on) during the summer months. The only drawback is the limited range on the dealer/port installed remote and the slight decrease in gas mileage.
  4. Osteoblast
    55
    NC
    Thanks so much!
