Remote starter option tweak
Discussion in 'Gen 3 Prius Technical Discussion' started by Goran, Oct 9, 2010.
  1. Goran
    Goran New Member
    Austin, TX
    I have 2010/III model with a remote starter option.
    I am planning to build a small enclosure and put a micro controller (Arduino) connected to a keyfob lock button, all enclosed. It will display time and some knobs to set it up. Then, at selected time, it will "press" lock button three times and start the car cooling cycle (and keep the car locked). That way I can program it, sort of as an alarm, to when I will be back to the car, and the car will wait for me air-conditioned.
    My question is, would it be possible to buy a key fob on the secondary market and have it program so that it only locks the door, and not be able to start the car?
    Also, would that even work? I have SKS and with the smart key I am able to do it from inside the car, but would a simple key be able to do it from the inside? (Is turning on the a/c a function of lock-door signal pressed 3 times, or it still requires sort of secondary authentication for the engine start)?
    thanks!
  2. Daytona Bob
    Daytona Bob New Member
    Daytona Beach Florida
    Why don't you just ditch the toyota remote start that way it doesn't cut off when you unlock the door.
    a Quality remote start will allow you to activate it from far enough away that when you get in the car is running with full AC.
    Good Luck though!
