Remote starter
Discussion in 'Gen 3 Prius Technical Discussion' started by ArturoGT500, Dec 30, 2009.
  1. ArturoGT500
    ArturoGT500 New Member
    Austin
    Once a Prius is started remotely, is there anyway to unlock and enter the car without killing the engine?
    If not, and along with no more auto lights for the gen 3 IV, this car is getting annoying.
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    As far as I am aware, with the stock remote starter, you cannot change the fact that it shuts the car off once the door is opened to get in.
    Honda remote start systems do the same thing. My friend has a new civic which does it as well. Makes the remote start completely useless IMO and not worth the extra price one pays for a factory system.
  3. scottwyden
    scottwyden new jersey photographer
    342
    New Jersey
    I don't think so.. That is their security so the car can't be stolen.
  4. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    ArturoGT500,
    Well I wouldn't bash the car for the Remote Start and Auto Lights. :(
    Honda and Toyota did this shutoff because of concerns of Theft. I don't like that they did it, honestly. I too, know of someone with a new Honda and it does the same thing.
    I suppose you could wait until Viper or some other vendor comes out with a compatible unit and see if you can change it out??? I don't know...
    As for the Auto lights, certainly not a deal stopper for me. Didn't have them on the Honda Civic Hybrid I traded in for the Prius so...not a big deal really. Sure it would have been nice to have them but then so would the Heads Up Display have been nice to have..
    I don't know of any way to circumvent the Stock Remore Start. Unless there is something the Dealer can "program" but you could double check...
    Good Luck!;)
  5. ArturoGT500
    Austin
    I appreciate the insight. I am not trying to sound off like a snob. However, I have had experiences with remote starters with other vehiclies.
    All other remote starters kept the engine on upon entry. Their security measure would be to kill the engine when you applied the break with no key in the ingnition.
    Also, our previous Prius' auto lights spoiled us rotten.
    It just seems that our Gen. II made it easier to get in and go.
  6. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    I gave up.
    The only reason for a remote starter on my G2 was for in the winter, pre-heat the car.
    I use a block heater combined with an interior ceramic heater, on a timer.
    The newer G3 and the future Prii have a remote heat/remote cool with the remote, that uses the HV battery. Should be sufficient for most people.
  7. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    The last few cars I owned had remote start that did not kill the engine when you open the door and auto head lights.
    I fixed the auto headlights issue with an after market auto headlight module. It works well. When XpressKit supports the Prius I will move to a normal remote start that keeps the car running for an unlimited amount of time and will not kill the engine when you start the car.
    Programmable Platform #05: Transponder Override Interface
    Toyota should let us choose how we want the remote to work. I am really getting fed up with all these safety restrictions we are forced to live with. Look how unsafe the concept of a motorcycle is, yet we are forced to have seat belt beepers, reverse beepers and a car that has to turn off before you enter it.
    By the way this is the 1,000th thread on this subject.
  8. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I agree, used to have them in several cars. Remote started, would turn off if brake was applied without TURNING the key to on.
    I agree there should be a better design. I contemplated buying the Toyota one myself for the new prius but since it has a few flaws, I have reconsidered it. On a good note this model surely heats up better with the Exhaust Recirc Unit.
    In fact I drive on HI temp and in PWR or NORM it cooks inside, compared to the previous Prius and Honda Civic.
    But maybe they will come out with an aftermarket that we can TUNE to our liking better...will have to wait and see.. :)
  9. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Yeah, I had a remote starter in a car back in the late 90's and even then that was the method of security... Once the brake pedal was pressed the car shut down.
  10. jp1960
    jp1960 Junior Member
    Central Mass. USA
    I have the Installed Remote Starter, and as others have said on this forum, it's auto shut-off feature is really a pain. And it makes no sense!
    The car is designed not to go ANYWHERE if no key is detected, obviously, if a car thief attempted to open the door and drive off with my Prius he couldn't do it, the car is disabled without the key!
    In addition, I find the car STAYS ON if I start the car and forget something, go back into my apartment, come back to the car, open the door, and THE CAR DOESN'T SHUT OFF! So, the stupid Toyota SAFETY FEATURE really doesn't do what it supposed to do all the time, you can work around the feature by remote starting the car, opening the car door, car shuts off, start the car again, go into your house, wait for it to warm up, come out again and get into the car and drive off, because the car doesn't shut off the SECOND time you open the door. The effect of this BOGUS "SAFETY" feature, in the end, is to aggravate the Prius owner!
  11. RodJo
    RodJo Member
    423
    56
    Boston
    Hmmm. I don't think that is true. Once the car is started, you don't need the key to drive away -- I just did it. It will warn you that no key is detected, but you can still drive away. There have been stories of people driving off without the key....
    Yes, if you want to start your Prius and leave it on the street to be stolen, Toyota will let you. Again, you don't need the fob to drive away. But that doesn't really mean that the remote starter routine is "bogus." It just means that you are willing to leave your car running. (And I wouldn't really call it the shutdown a "safety" feature, I view it as primarily anti-theft protection.)
    In addition, from other threads I'm not sure if the Prius is fully in Ready mode when using the remote starter. I forget what the answer is on whether the braking system is pressurized etc. It would seem wasteful to start everything up when not needed. So you may need to actually restart the car to even be able to drive away.
    Maybe the real issue is the misleading name. It's not really as much of a remote starter as it is a remote HVAC starter.
    Anyway, I have no problems with it (other than getting the hang of the button pushing sequence) and I really don't understand the frustration with the shutdown. The complaint seems to be that you have to push the START button after you get into the car. How big of a "pain" can that possibly be? It's not like you have to even reach into your pocket and find your keys.
  12. gregleder
    gregleder New Member
    Minneapolis
    I have a new 2010 Prius with remote start and the sunroof. I am having very inconsistent results using the remote start to warm the car up on these cold mornings. Most of the time the car starts for just a second and then turns off. Other times it works fine. When I took it to the dealer they tried it several times and it worked just fine. The very next morning - same inconsistent results. HELP....
  13. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Someone correct me if I'm wrong, but isn't the remote start on the solar roof cars for purposes of A/C only, to allow it to run off the batteries for a few minutes? It's not really the same as the remote start option available as an add-on for the other models (which is what is being discussed in this thread). I'm not sure the other remote start option is available on the solar models, but my guess would be yes. FWIW, not worth it IMHO (speaking as one who paid for it).
  14. gregleder
    Minneapolis
    Thanks - I am talking about the remote start for the actual car engine to run the heater, etc... (not talking about the solar cooling fan). But I am guessing that I may be having some interaction between the two that is making the remote start for the heater not work right??? I'm hoping some else has both and can figure out why I'm having mixed results.
  15. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Well, I can tell you the timing of the button presses has to be just right for the engine to turn on. 2 quick presses of the LOCK button, followed by another quick press, at which point you should get the confirming flashing of lights. Can be a PITA to hit it just right. I assume the dedicated remote button for the solar cars only does the A/C thing.
  16. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    Does the dealer installed remote starter use a dedicated fob or is the OEM fob just reprogramed? Negating one more thing on the keyring. Thanks.
  17. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    They just use the normal OEM fob. 2 quick presses of the lock button, followed by a 3rd press.
  18. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Thank you.
    Unlock car. Get in. Foot on brake. Press button. It's the same whether or not you have the remote start and whether or not you have the vehicle remote started or not.
    Vehicles with keys require you to put the key in the ignition and turn it to the ON position when you get into it after a remote start command...why wouldn't the Prius require you to put it in the ON position as well?
  19. Judgeless
    1,821
    255
    Cleveland, OH
    I totally disagree. The car is full of convenience features. Heated seats, power windows, intermediate wipers, power steering, power brakes, auto door locks, ect… Leaving the car running should part of that group.
    Having to turn car off after you use remote start it is foolish at many levels. Yes it is true that someone can break the window and drive off with the car without FOB. They can also pull up with a tow truck and drag the car away. If someone wants your car they can get it.
    I believe the best solution would require the door to be open with the FOB nearby and the car should just keep running. If someone breaks the window and does not have FOB to unlock the door the engine should turn off.
  20. chrisj428
    680
    144
    35
    Vernon Hills, IL
    You're missing my point (or maybe I'm not making myself clear).
    Everyone seems to be complaining about two things -- the logic and the steps. While we might take (valid) exception to the logic of the operation, the steps required to drive off in the car are the same, whether the car has been remote-started or not.
