Remote wont work anymore
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kaotickevin, Jan 27, 2015.
  1. kaotickevin
    kaotickevin New Member
    foster city , ca
    I have my 2011 and all of a sudden my car stopped being able to sense it in the car or outside the car. The lock and unlock function still works which is puzzling, and when I tapped it to the power button in effort to start the car, the car still does not start and says it can't locate the key. I dropped a 85lb weight on it the other week at the gym but it appears there wasn't any damage when I took the key apart, and it was working fine up till now. The spare works fine, but I'm just hoping I don't have to buy another key =/
    Any suggestions on where to buy it, or is the dealership the only real option. TIA
    also noticed this is the same part number, and since i only need the new circuit board I'm assuming, I wonder if its the same size as the prius one
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Swap the battery between the spare and and broken one and try... You could just have a low battery.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Into the fog of London Watson! We have a clue!
    Dash your hopes...a purchase is in your future!
    Mendel Leisk and RRxing like this.
    49,458
    definitely try a new battery before a new fob. also, check to make sure a button isn't stuck. did you put the battery back in the right direction? if you do need a fob, do your due diligence, it's a complicated process and a lot of threads here on the subject, if you don't want to spend $400. at the dealer.
  5. kaotickevin
    foster city , ca
    haha yea not a low battery tried a new one guess ill start looking for a replacement
  6. GregP507
    GregP507 Senior Member
    3,002
    480
    I had this happen shortly after I got my car. I wasted money on a new remote battery, but the problem was caused by the smart-key functions being inexplicably turned off. I was able to turn it on again by navigating in the "car" menu in the head unit.
    I've noticed a few strange things like this happening; some times things can spontaneously reboot themselves with different settings. In lieu of a better explanation, I'll put it down to errant EM field-eddies created by the hybrid system.
