Removal of EGR Valve and Cooler Permanantly
Discussion in 'Gen 3 Prius Accessories and Modifications' started by BLee3, Jun 4, 2018.
  1. BLee3
    BLee3 New Member
    South Dakota
    Hey everyone, After reading up on this forum regarding cleaning the egr valve and cooler, I came to wonder why not just remove the whole system. I Live in SD, so I do not believe we have emission laws or checks. would the 3rd Gen Prius run just fine with out the hassle of EGR? To me it seems that the engine would run much more efficient burning air that has not already been burned, if you know what I mean. Just throwing it out there and wondering if anyone has done it already? Also would eliminate the carbon buildup in the intake and valves.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    computer will know and throw check engine light
  3. Mendel Leisk
    41,515
    I'm not 100% sure why, but apparently properly functioning EGR is keeping the engine significantly cooler running. I would clean it, end-to end, clean the intake manifold as well, and install a decent oil catch can along the line between pcv valve and intake manifold. The OCC install will hopefully reduce the propensity of the EGR to clog up again.
    @mjoo has more explanation/understanding as to why the EGR keeps the engine cool I think.
  4. BLee3
    BLee3 New Member
    South Dakota
    Hmmm.... I would like to know how that is. Thanks for the info.
  5. BLee3
    BLee3 New Member
    South Dakota
    Yes, don't want that to happen, would be annoying. But emission equipment seems a little useless, just wondering if there was a way to do it and not throw a code.
  6. tankyuong
    1,555
    661
    Central MO
    somehow drill the egr valve straight through where there's no fins left to clog
  7. Mendel Leisk
    41,515
    Please don't do that. For starters, there's coolant flowing through passages there, and the fins are there to cool the exhaust gasses.
    This thread is churning up too much misinformation methinks?
    #7 Mendel Leisk, Jun 7, 2018
  8. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    You can put lighted candles in the holes so it can burn the excess oil and dry the moisture passing all in one.
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    ROFLMAO!!!!! That was a good one!!!!!:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:(y)(y)(y)
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,056
    539
    Tucson, AZ
    2021 Prius
    My understanding of it is that a properly functioning EGR valve injects a metered volume of exhaust gas into the intake fuel-air mixture. Because this effectively replaces some of the air with a non-combustible gas, the resulting temperature of the ignited air-fuel mixture is decreased. This was originally done to reduce the formation of NOx, and now it also appears to prevent overheating which protects your head gasket.
