Remove Door Panel
Discussion in 'Gen 3 Prius Main Forum' started by sprius*, Aug 24, 2010.
  1. sprius*
    sprius* Junior Member
    New Jersey
    Would someone please tell me how to step-by-step remove the passenger front door panel on a 2010 Prius without doing any damage? Thank you.
  2. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The technical sub-forum will be probably better for this kind of question.
    1. [FONT=Verdana,Bold][FONT=Verdana,Bold][FONT=Verdana,Bold]REMOVE FRONT DOOR INSIDE HANDLE BEZEL PLUG - 3 claws on perimeter[/FONT][/FONT][/FONT]
    2. [FONT=Verdana,Bold][FONT=Verdana,Bold][FONT=Verdana,Bold][FONT=Verdana,Bold][FONT=Verdana,Bold][FONT=Verdana,Bold]REMOVE ASSIST GRIP COVER - 6 claws, 2 clips on perimeter[/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]
    3. [FONT=Verdana,Bold][FONT=Verdana,Bold][FONT=Verdana,Bold]REMOVE POWER WINDOW REGULATOR SWITCH ASSEMBLY WITH FRONT DOOR ARMREST BASE PANEL 7 claws on perimeter, disconnect the connetor[/FONT][/FONT][/FONT][FONT=Verdana,Bold][FONT=Verdana,Bold][FONT=Verdana,Bold]
      [*]REMOVE DOOR ARMREST COVER
      [/FONT]
      [/FONT]
      [*]REMOVE COURTESY LIGHT ASSEMBLY - 1 claw at short edge on right side
      [/FONT]
      [/FONT]
      [*]REMOVE FRONT DOOR TRIM BOARD SUB-ASSEMBLY - many clips around perimeter
    Don't worry too much about the damage. the plastics are quite durable. Use the plastic clip/molding remover. Usually when you insert the plastic remover between parts, you will see where to pull. Toyota recommends to disconnect the '-' (black) pole of the battery in the cargo area usually, but it is not a must if you are far away from the airbag locations.[/FONT][/FONT][/FONT]
