Remove map light panel.
Discussion in 'Prius v Main Forum' started by sean v4, May 23, 2015.
  1. sean v4
    sean v4 Junior Member
    Corona, CA
    2015 Prius v wagon
    Does anyone know how to remove the little blank piece at the map light where the finger is pointing at?
    I have tried to use a small flat head and it does seem to pop out.
    Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,987
    4,731
    Texas Hill Country
    You have to take out the whole map light assembly although it's just 4 clips that hold it in. Then there "may" be two screws on the back that hold the smaller panel in.
