Remove passenger seat but airbag sensor attached?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Drewintoledo, Feb 5, 2016.
  1. Drewintoledo
    Drewintoledo Junior Member
    49
    Ohio
    2015 Prius v wagon
    Ive removed my passenger seat from my 2015 v but when I tried lifting it out I was stopped by a wire connecting the seat. I noticed an airbag warning label on the wire
    My question: Is it ok to disconnect this sensor to remove the seat while I perform some work?
  2. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Yes, but disconnect the 12v auxiliary battery negative/ground terminal first. Wait about 20 minutes to be sure that all capacitors are completely discharged, then it's safe to disconnect/connect wiring to the airbags.
    On second thought, it's the sensor, not the airbag, so it might not be necessary to disconnect the battery. It's just a sensor to detect the weight of the passenger on the seat. It doesn't have anything to do with triggering the airbag.
    #2 xliderider, Feb 5, 2016
  3. Drewintoledo
    49
    Ohio
    2015 Prius v wagon
    That's along the lines that I was thinking. If the sensor says it's off, it shouldn't matter anyways. Thanks for the quick response. I may get brave tomorrow and just pull it!
  4. Air_Boss
    Air_Boss Senior Member
    3,953
    1,084
    New Yawk
    Disconnect the 12V battery. You don't want to see whether you get and stay lucky.
    xliderider likes this.
