Remove silkscreen(?) ink from plastic switch?
Discussion in 'Fred's House of Pancakes' started by egg_salad, Sep 9, 2018.
  1. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    After much searching, I finally found a junkyard switch that fits the G2 dash. However, it has an icon I don't want. Does anyone know of a solvent that will remove the icon but not damage the underlying plastic?
  2. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    It depends on what kind of plastic and ink it is. The ink is generally a solvent base that is either silk screened or pad printed. Here is a document that can give you some kind of guidance. There are some videos on the internet that show how to identify plastics, but it is likely the switch is ABS.
  3. egg_salad
    545
    426
    Las Vegas, NV
    Thanks for your help. Although I'm fairly certain the switch is ABS, beyond that, your linked document is stratospherically over my head.
  4. ChapmanF
    17,347
    Sometimes, if the switch is meant to be illuminated, the 'ink' is where the black surface is graven away to let the light through.
    -Chap
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    If you're going to re-screen print it, can you do it in a dark grey layer first?
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    After I buy a car, the fear is the image fading away. I've never really thought about trying to remove an image.
  7. egg_salad
    545
    426
    Las Vegas, NV
    Oh. Huh. I hadn't thought about that, but you're probably right. A few quick dustings of Krylon Fusion ought to solve my problem.
