Remove the soldering
Discussion in 'Gen 2 Prius Audio and Electronics' started by brooks ghu, Feb 3, 2008.
  1. brooks ghu
    brooks ghu New Member
    enjoyed the detailed explanation above on brazing. I have a question going in the reverse direction. How do you unsolder or unbraze a silver-soldered joint between stainless steel and brass without destroying optical components housed within?
  2. mkiefer83
    mkiefer83 Junior Member
    45
    Ypsilanti, MI
    Very carefully
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    There are some commercially made copper braids, sold under names such as SolderWick, which can be used with flux and heat to draw off the brazing material (in this case silver solder). You dip the braid in flux, then press it onto the joint and heat the joint and the braid. Once the solder melts, capillary action will draw out most of the solder.
    Tom
  4. hery jeck
    hery jeck New Member
    I don't know the answer to your question but I want to make a guess. Are you want information about brazing so you can go my link Induction Brazing thanks
