Removing 100A Fuse
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Blue2, Nov 20, 2019.
Tags:
  1. Blue2
    Blue2 New Member
    100A fuse blew in 2013 Prius C. 12v battery was installed backwards, so pretty sure that's why.
    Has anyone replaced the 100A fuse under the hood on the driver's side? It seems it is possible to disassemble the fuse box into at least two parts to access the screw on the underside of the fuse box holding the 100A fuse in. So far removing the two fasteners that hold the fuse box to the body has not provided sufficient access to the 100A fuse screw.
    Have done quite a bit of searching over the past two days but couldn't find anything for Prius C. Any help is much appreciated.
    Vit@liy likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,145
    5,321
    Pacific Northwest, USA
    Not sure if Prius C is different, but in Gen2 Prius there's going to be additional damage beyond that fuse you're gonna have to fix... So if you can't find that info on here for Prius C, try to find it for Gen2, where there's an abundance of info about damage caused by jump start when polarity was accidentally reversed.
  3. Blue2
    Blue2 New Member
    To follow up on my post: Tested all the fuses with an amp meter and found approximately 6 fuses blown. Was able to replace approximately 5 fuses besides the 100A one myself. I spent a good chunk of time trying to take apart the driver's side fuse box to access the screw(s) holding the 100A fuse in, but finally gave up. Ended up taking to the dealer. Seems they didn't know how to take it apart either because they cut a silt into the plastic to access the 100A fuse. According to the dealer, no damage beyond the $15< fuse - so if you are reading this because you made the same mistake I made, there is hope!
    Vit@liy likes this.
  4. PriusCamper
    13,145
    5,321
    It's always so fascinating how often the dealers are so new to the finer points of repairing hybrid cars...
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    We are only required to have 1 (yes one) certified hybrid technician. That certified tech is only required when repairs are made under warranty. So if your vehicle is out of warranty, the service writer will give it to whomever they choose.
  6. PriusCamper
    13,145
    5,321
    Thanks for that information... That explains alot... I guess Tesla won't ever have a problem like that? :)
    dubit likes this.
  7. Vit@liy
    Vit@liy Junior Member
    Ukraine, Lviv
    2015 Prius c
    Unfortunately today I also made the same mistake :( (switched battery polarity)
    Does anyone have any updates how to properly remove fuse box on our Prius C?
    Could you pls. clarify where were the other 5 fuses in your case?
