Removing Dealer Painted Name, etc. from Car
Discussion in 'Prime Main Forum (2017-2022)' started by Russ Bohn, Sep 3, 2017.
  1. Russ Bohn
    Russ Bohn Junior Member
    31
    Overland Park, Kansas
    The dealer put their name, etc. on the left rear area of the the car, right under the Prius Prime badge.
    Meet the 2017 Toyota Prius Prime in its West Coast debut | PCWorld
    It looks like they may have had a minimum wager use a stencil and paint to put their dealership name information on my car. I did not want them to do that! They did not pay me anything to advertise for them.
    Any idea how to get this off, without destroying magnetic grey underlying paint?
    They also gifted me a license plate frame with their name on it as well.
    That, my friend Cersei Lannister can help me with....
    Dudley1030 likes this.
  2. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    It is probably a decal. See if you can feel the edge.
    Of course you could take the car back to the dealer and insist they remove it. That's what I would do. The license plate frames given to went straight in the trash. As do all of the mailers for stealership service.
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Mine was a sticker. I just peeled off all the bits and wiped it down with a little alcohol. Gone.
  4. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    I picked mine up from the dealership so quick after it came in that they did not have time to add their name to the car.
    bps and priuscatprimeguy like this.
  5. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Removing the dealer's sticker was one of my requirements for purchase... They obliged, no problem...
    bps and Prodigyplace like this.
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Take the frame off, turn it around backwards and put it BEHIND the plate.
    That will stiffen the plate, making it less likely to rattle and will probably give you a nice border around the plate too.
    WilDavis and Trollbait like this.
  7. Trollbait
    12,679
    It is likely a decal like that used for pinstriping. There is a 3M buffer head designed for removing it, but I always just used my finger nail.
  8. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    You can request ahead of time that they not put a decal on. Of course they may forget and do it anyway, in which case you can ask them to remove it, or as others have said it's pretty easy to remove it yourself, especially since it was recently applied. I think it would be harder to remove say two years later.
  9. Trollbait
    12,679
    Two years later, it might be coming off on its own.
    William Redoubt likes this.
  10. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    If it is a decal, which it almost certainly is, use a hair dryer on hot to soften the letters. Once they are soft, peel them off with your finger nail, then wipe the remaining glue residue off with alcohol or bug and tar remover.
    You can do it faster yourself than taking it to the dealer and asking them to do it.
  11. Russ Bohn
    31
    You were correct. Took my fingernails and removed the dealer's sticker logo, then used a mixture of windex and WD-40 to take off the adhesive. Looks much better.
  12. jungleland1972
    73
    65
    Chesapeake Beach, MD
    I did the same thing (used a blow dryer to make the sticker easier to remove). If you look really hard, you can still see a bit of glue where the stickers were so I am going to spend a bit more time cleaning it with WD-40 and hot water to see if I can get it all off.
  13. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …you (or your tame lawyer) could send the dealer an invoice for advertising! ;)
  14. Trollbait
    12,679
    I'd be happy with just being able to write off all my miles for taxes.
  15. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    My car had logo of different dealer when I test driving it. After closing a deal two hour later, they detailed the car. The logo from the different dealer was removed and they replaced it with their own logo. It was just a sticker and came right off without any cleaning. If any residue is left, something like this would help.
    Car Label & Sticker Remover - Turtle Wax
    #15 Salamander_King, Sep 11, 2017
  16. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Fortunately for us Californians, state law prohibits dealers from doing so.
  17. CharlesH
    2,797
    1,165
    Roseville, CA
    But they can (and do) put on dealer license plate brackets.
