Removing driver side floor matt posts
Discussion in 'Gen 3 Prius Accessories and Modifications' started by willrob, Jul 28, 2012.
  1. willrob
    willrob Junior Member
    33
    Madison, Wisconsin
    I'm not sure I'm using the right term for the posts. I have the Heavy Duty floor mats that do not have the opening for the posts nobs to fit into, so there is a slight bulge where the mat sits over the fitting. In previous models (I have a 2012), it was possible to pry out the posts. Has anyone discovered a way to remove the 2012 model's posts? Or will I just have to live with the bump.
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Or you could drill holes in the mats. :)
    Jason dinAlt likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    A punch would probably make a cleaner hole.
  4. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Those nobs are there to keep the mat from sliding up under the gas pedal. When the mat gets old, it will jam the gas pedal mechanism if it's not attached to those nobs.
    I recommend putting some holes in the mat so that it can be attached to the nobs.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    He probably wants no holes for water to leak down. Just my guess.
  6. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    The 2012's have the 1/4 turn tabs that do not just work with any hole. they have to work with the special eyelets. AFAIK Weathertech is the only after market with the correct fastener on the market as of right now.
  7. ES44AC
    ES44AC C.A.U.S
    319
    77
    Wish the passenger side had those knobs/pins as well. At least it wold keep the mat from sliding forward allowing the carpet to get dirty.
  8. Jason dinAlt
    Jason dinAlt Member
    183
    61
    Seal 'em.
  9. ES44AC
    ES44AC C.A.U.S
    319
    77
    Been done.
